Dual Quadrajets ? #1530582
11/09/13 02:43 PM
11/09/13 02:43 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Got my latest issue (Nov 13) of Muscle Car Review and it has a nice write-up about Dick Harrel and Nickey Chevy and how they put a 427 in one of the first Camaro's in late 1966. They said with 8" slicks and 4.56 gears it ran 11.90's @ 114. But then it says they took of the single Holley carb and put 2 Quadrajets on it and ran 11.40's @ 126 ! Wow 12 mph pick up ? Dont sound right to me but it is a cool write-up. I cant say I have ever seen anyone run dual Quadrajets either ? Ron
Re: Dual Quadrajets ? [Re: 383man] #1530583
11/09/13 02:57 PM
11/09/13 02:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There's a picture floating around here of a guy running dual Thermoquads on a tunnel ram.I don't see why it couldn't be done with a Q-JET
Gus
64 Plymouth Savoy
Dana 60
Re: Dual Quadrajets ? [Re: fourgearsavoy] #1530584
11/09/13 03:47 PM
11/09/13 03:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Might actually work pretty well at lower RPM, what with teh small/higher velocity primaries.
12 MPH would seem to indicate that the thing was starved for airflow with the single carb; that's a big bump, though, maybe something else was tweaked at the same time.
Re: Dual Quadrajets ? [Re: topside] #1530585
11/09/13 04:03 PM
11/09/13 04:03 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thats what I was thinking. They dont have a pic with the dual Quadrajets. Ron
Re: Dual Quadrajets ? [Re: 383man] #1530586
11/09/13 04:19 PM
11/09/13 04:19 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
I had talked with Ronnie Sox in the 70's at 75-80 dragway in Maryland about carbs. He mentioned they had tried dual Thermoquads on their pro stock Colt. It was quicker on both et and mph (he did not say how much), but it was not very consistent. Thus, they dropped the idea. Perhaps the quadrajets had the same problem.
Re: Dual Quadrajets ? [Re: 383man] #1530587
11/09/13 04:45 PM
11/09/13 04:45 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Saw dual q-jets on a Buick in the "70's" I think the same guy had dual t-quads on a tunnel ram.
Re: Dual Quadrajets ? [Re: 383man] #1530588
11/09/13 05:37 PM
11/09/13 05:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
12 MPH, I don't have time to do the math but what is that about 150HP at that level?
Sheldon
Re: Dual Quadrajets ? [Re: topside] #1530589
11/09/13 06:40 PM
11/09/13 06:40 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
The most obvious other change would be the intake. Did they go from a stock low, single plane cast iron intake, to a tunnel ram? And how small was the single Holley?
Brian
Re: Dual Quadrajets ? [Re: '72CudaRacer] #1530590
11/09/13 10:43 PM
11/09/13 10:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The member running the dual Thermoquads is quickd100, they're on a 605 HEMI and he loves them
Re: Dual Quadrajets ? [Re: WO23Coronet] #1530591
11/09/13 11:00 PM
11/09/13 11:00 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Yep....That be me. They cost little or nothing and with a bit of tuning they can scream.
I made 18 dyno pulls on the 528 to get them where I wanted them but it was well worth it. On the 605, IF I drive it nice it geats 10mpg. That's with 4.56 gears, 10" TA convertor, and a custom Bullet solid roller that's 288/292 duration@.050 and .767 lift on the intake.
I love thermoquads, on Speedtalk one guy quoted a Rochester Carb engineer that said; (The thermoquad is the next step in evolution of the spreadbore after the quadrajet.) Dave
