440 Fires up - BUT will not idle. SOLVED - Thanks
#1530453
11/09/13 10:28 AM
11/09/13 10:28 AM
Posts: 1,336 Massachusetts, USA
MASSMOPAR
Massachusetts, USA
Took a running recently rebuilt E440 Steel Crank engine, We then rebuilt the top end. New Holley Six pack New Edlebrock intake New E-Street alum heads New MOPAR .509 Cam New lifters, push rods timing chain, gaskets etc. New MSD Electronic ignition Starts up and runs now - BUT races up then down, up and down, then won't idle STALLS when let off the throttle. Any thoughts?
70 Road Runner 528 HEMI 4sp FY1
70 Road Runner 440+6 V-Code AG 4spd EV2
69 R/T 4 Spd Dana 3:54 AG Vert B5
69 R/T 4 Spd Dana 3:54 AG X9 V1X V8R-WORKING
69 R/T Auto/Console 8.75 SG Vert R/T B3
08 Challenger 1st Edition Hemi Orange
69 Super Bee 4 Spd 8.75 SG AG F8
Re: 440 Fires up - runs nice @ high RPM BUT will not idle.
[Re: MASSMOPAR]
#1530458
11/09/13 11:54 AM
11/09/13 11:54 AM
RapidRobert
Just me I think I'd pull the intake bolts & get a rough check on the port alignment via the bolt hole alignment & assuming that is in the ballpark then pull the intake & use some Permatex #2 around the 8 port openings on the valley pan (both sides), a light/EVEN coat & if that does not take care of it then go to work on the carbs
[Re: MO_PA]
#1530460
11/09/13 05:49 PM
11/09/13 05:49 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
6pack needs more timing than a 4BBL...and I agree on vacuum leak
....Especially with that cam. And I agree that there is a good possibility the intake has a vacuum leak. I had the .509 in my Challenger with the 6 pack. It had worse idle issues than the 270* @ .050 race cam in there now!!!
[Re: MASSMOPAR]
#1530463
11/09/13 09:34 PM
11/09/13 09:34 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
If the rpm wonders at idle, it is likely a vacuum leak. And it could be between the intake and head.
Plus what everyone else said about cam and timing
[Re: Mr.Yuck]
#1530465
11/09/13 11:59 PM
11/09/13 11:59 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Check your initial timing not total timing...you want as much as initial timing as the engine can take before kicking back on the starter...
msd distributor..what bushing do you have in it?
someone is selling 10 degree bushing in the for sale section...
and the engine vacuum has no bearing on the end carbs opening..as they opened based on the center carb...not the engine...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1530466
11/10/13 01:30 AM
11/10/13 01:30 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Disconnect the vacuum advance and plug it. Adjust the timing again and see how it does.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1530467
11/10/13 01:41 AM
11/10/13 01:41 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
""and the engine vacuum has no bearing on the end carbs opening..as they opened based on the center carb...not the engine..."" sooo your saying the center carb makes the vacume ?? I believe you are wrong..
I am truckless..
[Re: 70AARcuda]
#1530470
11/10/13 12:54 PM
11/10/13 12:54 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
perhaps, as the linkage has to be "open" for the blades to open, but if you say have a 6.5 PV and the vac drops to 3-4 it's not going to run right.
I tuned my 6-pack out of the box like this... unhooked the outboards, turn the mixture screws all the way in then back out 1 turn, turn the idle screw up to about 2200, unhooked vac advance, fired the motor, let it warm up set advance to 38* in at 2200, brought the idle back down to 900 or so, set mixture screws for best vac reading, hooked up the outboards and went for a blast. However if you have a vacuum leak, that's not going to work.
