I have read the tech page on this on changing the thrust plates to needle bearings but can't seem to find any info on which bearings work in a A518/RH46 transmissions.
If anyone has a list on the numbers can you post here or PM me.
The machine work won't be a problem as I have access to large lathes or mills.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
