Too much compression for local pump gas octane? #1530174
11/08/13 03:38 PM
11/08/13 03:38 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I'm finishing putting my engine back together and wondering if I can still get away with pump gas after the latest changes.
It's a 440 bored .055 oversize, .047” quench, ported Indy SR heads with cleaned up chambers, and a 260 at .050" solid roller on 108 advanced 2 degrees.
The car is 3800 lbs with driver, has a 4200 stall converter, 4.10s, 28" x 10" DOT meats and a 3" exhaust system.
I just ran the numbers for the compression ratio now that I have all the details and came up with right at 11:1. From what I saw in the past, it'll probably have close to 190 psi cranking pressure.
The local pump fuel is 92 octane (ROM+MON/2) w/ 10% ethanol. Is this going to work OK, or am I going to wish I'd gotten dished pistons instead of flat-tops to have lowered the compression? Maybe I just need to be extra careful about the ignition timing? It used to run fine with a little lower compression at 36 degrees total.
Re: Too much compression for local pump gas octane? [Re: PorkyPig] #1530175
11/08/13 03:41 PM
11/08/13 03:41 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
With that quench and aluminum heads, you will be fine.
I will be suprised if you have that much cranking compression with a cam that big.
Re: Too much compression for local pump gas octane? [Re: TheOtherDodge] #1530176
11/08/13 03:53 PM
11/08/13 03:53 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
The old build has about 1/4 point less compression, about 5 degrees bigger cam, and cranked about 180 psi. So, I figure it's going to go up a bit, all else being the same.
Re: Too much compression for local pump gas octane? [Re: PorkyPig] #1530177
11/08/13 03:56 PM
11/08/13 03:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm at about 11.2:1 and run 93 with 38* total in full at 2200. I do however have a meth/H2O kit. I think you'll be ok. However if you want to ru hard at the track I'd put a few gallons of 110 in it.
Coming soon!!!!
Re: Too much compression for local pump gas octane? [Re: PorkyPig] #1530178
11/08/13 03:59 PM
11/08/13 03:59 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
My 512 kit with flattop and 75cc Eddy heads has 12.42 it pumps 185#.On 93 pumpgas timing at 34*.
Section 8 Racing We are nuts about racing.
Re: Too much compression for local pump gas octane? [Re: PorkyPig] #1530179
11/09/13 02:05 AM
11/09/13 02:05 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm not sure if you're on the borderline or not... I'd back off on the timing a couple of degrees and run a colder plug to start with to be safe.
Re: Too much compression for local pump gas octane? [Re: BradH] #1530180
11/09/13 10:58 AM
11/09/13 10:58 AM
Az
Crizila Offline
Crizila  Offline
Az
Trust me, you are on the boarder line. I think you knew this with the post. Above suggestions will help. If you don't want to change the motor, maybe water injection as an added safety. One bad load of fuel and you will be pulling the motor.
Fastest 300
Re: Too much compression for local pump gas octane? [Re: Crizila] #1530181
11/09/13 11:24 AM
11/09/13 11:24 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That's no lie! I recently got a tank full of what was probably 87 octane instead of 91 like it was sold as, and it wasn't good. I pumped out a third of the tank and put some 110 in it to salvage what was left. You REALLY have to pay attention or it will get ugly and expensive quickly.
For sure keep the timing in check until you know what it likes.
Re: Too much compression for local pump gas octane? [Re: Duner] #1530182
11/09/13 11:32 AM
11/09/13 11:32 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I think you need to tighten up the quench, my 440 has .030 quench with 11.1 compression. I also have SR heads and the motor is on the edge with 91 octane.
Re: Too much compression for local pump gas octane? [Re: PorkyPig] #1530183
11/09/13 12:24 PM
11/09/13 12:24 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
What's the elevation where you live?
Re: Too much compression for local pump gas octane? [Re: Triggerfish] #1530184
11/09/13 02:09 PM
11/09/13 02:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am at 10.6 with EZ aluminum heads and a solid flat tappet thats 264 & 270 @ .050 and .585 & .592 lift. Quench is .046 and I run 37 total timing. Intake valve closes at 58 ABDC. Runs good on 92 pump with no problems. I just raced it 3 weeks ago on the 92 and thru the full exh. I am in Md close to sea level. Ron
Re: Too much compression for local pump gas octane? [Re: Crizila] #1530185
11/09/13 05:57 PM
11/09/13 05:57 PM
BradH Offline
BradH  Offline
The reason I wasn't (and am still not) sure is because my 452 ran on 93-octane ethanol-blended fuel with no detonation problems. It had 10.8 CR and a 266 at .050" solid flat-tappet cam.
Is adding .2 in CR, subtracting 6 degrees of duration and dropping 1 point of advertised fuel octane going to change things from a perfectly "happy" combination into an issue? I dunno...
Re: Too much compression for local pump gas octane? [Re: bentwheel43] #1530186
11/11/13 12:21 PM
11/11/13 12:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Say Bentwheel, a little off topic, but how's that big stroker like the Holley Street Dominator intake? Thinking of a combo similar to that with that intake in an A body.
