How much stroke will stock HEMI block accept? #1530056
11/08/13 11:27 AM
11/08/13 11:27 AM
Carroll, IA
jercars Offline OP
jercars  Offline OP
Carroll, IA
Thinking of putting some bigger guts in my hemi looking for some times. Factory block casted in 1973 bored .030. I'd like to stick with that bore since the holes are in perfect condition. How much stroke can I throw at this thing without getting into clearance issues. A Little grinding doesn't bother me but I don't want to go crazy on it since it's just a street car.
Re: How much stroke will stock HEMI block accept? [Re: jercars] #1530057
11/08/13 11:44 AM
11/08/13 11:44 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
If you want to stay with the internal oil pickup 4.25 with the Chevy rod size is a good fit. If you go to a external pickup I know the 4.5 will work. Anything larger I am not sure of.
Getting old just means you were smarter than some and luckier than others.
Re: How much stroke will stock HEMI block accept? [Re: jercars] #1530058
11/08/13 12:04 PM
11/08/13 12:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Thinking of putting some bigger guts in my hemi looking for some times. Factory block casted in 1973 bored .030. I'd like to stick with that bore since the holes are in perfect condition. How much stroke can I throw at this thing without getting into clearance issues. A Little grinding doesn't bother me but I don't want to go crazy on it since it's just a street car. Also the motor came with a Comp Thumpr cam and I have zero experience with that series. I don't have the specs with me but I think lift was around .500 and .525 and duration was around 305°. Anyone ever tried one?
With 2.200 Chevy pin,large bore clearences and external oiling you can go up to a 4.750 but with a .030 bore I would suggest you keep the stroke to 4.500 or less.A 4.500 stroke and 4.310 bore will net you aprox.526" at 4.270 a little less.Ideally for street 4.150 at your bore will net you just under 500" and make a great street/strip engine.We usually see those 471" to 484" engines make power equal to the 500".
Re: How much stroke will stock HEMI block accept? [Re: jercars] #1530059
11/08/13 02:37 PM
11/08/13 02:37 PM
I have built several different sizes of Street Hemi with 3.90 stroke to 4.375 stroke. My favorite would be (if I owned a Hemi now, which I don't anymore ) would be a 4.25 stroke with BB Chevy rod sizes and use a decent set of 7.100 long BB Chevy type H beam rods with the .990 BB chevy wrist pin sizes also That may require a custom piston instead of a shelf piston but it will ne worth the additional costs of that piston. If it is a iron headed pump gas street motor keep the compression under 10.5 to 1 It should really set you way back in the seat at WOT once it hooks the smoking tires up
Re: How much stroke will stock HEMI block accept? [Re: Cab_Burge] #1530060
11/08/13 10:40 PM
11/08/13 10:40 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Using a 2.2 pin size and a 7.1 rod a 4.75" crank will fit with very little clearancing.Dave
Re: How much stroke will stock HEMI block accept? [Re: Cab_Burge] #1530061
03/05/14 11:51 AM
03/05/14 11:51 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I'm thinking about this combination for a project I am working on. However, I have a couple of questions. I am thinking about using the block form MP p/n 5155072AB, currently listed at Summit. Can I use internal oil pickup? The crank I have is a 4.25, Ohio Crank (came with parts I bought). I need to turn the rod ends down to 2.2 for Chevy rods. I was going to drop Diamond Pistons a note asking if they have a piston for this configuration. Is there any other comapny I should contact? I would like to keep the engine looking as sock as possible, so I am not too interested in external oil system.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: How much stroke will stock HEMI block accept? [Re: Cab_Burge] #1530062
03/05/14 06:02 PM
03/05/14 06:02 PM
California
mickm Offline
mickm  Offline
California
that's my setup, but i have a mopar siamese block, so don't' think that counts as stock.
didn't have to modify anything, and using the stock internal pickup.
Re: How much stroke will stock HEMI block accept? [Re: Cab_Burge] #1530063
03/05/14 06:22 PM
03/05/14 06:22 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
You just described my 540 except I have alum heads and more compression (will drop it next time). The rod ratio with that 7.1 rod should help the side loading. Also, with a 4.25 stroke you can use a Milodon windage tray.
