Odd Exhaust Port Coloring #1530028
11/08/13 12:52 AM
11/08/13 12:52 AM
Cascade, CO
reknapp52 Offline OP
Cascade, CO
Getting ready to build a new set of headers, so removed the old ones today. Exhaust ports are a little curious-looking, the front port on both sides of the motor are quite dark, and the other 3 are a very light whitish-gray (see pics). Maybe an anomoly of throttle-stop racing? (My Dedenbear throttle stop has the secondary blades almost completely closed when on the stop). Both pictures are of the right side of the motor, the left side is identical. Any thoughts, opinions, or similar experiences?
Re: Odd Exhaust Port Coloring [Re: reknapp52] #1530029
11/08/13 12:53 AM
11/08/13 12:53 AM
Cascade, CO
Cascade, CO
2nd pic.
Re: Odd Exhaust Port Coloring [Re: reknapp52] #1530030
11/08/13 01:00 AM
11/08/13 01:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The grey ones are normal. The black would usually indicate oil in the exhaust side. Likely from a guide leak.
Re: Odd Exhaust Port Coloring [Re: Al_Alguire] #1530031
11/08/13 01:53 AM
11/08/13 01:53 AM
Cascade, CO
Cascade, CO
Thanks Al, I didn't even think about a leaking valve seal, they don't have much time on them. Guess I'll be replacing them.
Re: Odd Exhaust Port Coloring [Re: reknapp52] #1530032
11/08/13 04:18 AM
11/08/13 04:18 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Could it be fuel distribution?? I have always seen oil streaks with a leaky stem seal.
Re: Odd Exhaust Port Coloring [Re: dartman366] #1530033
11/08/13 11:43 AM
11/08/13 11:43 AM
Cascade, CO
Cascade, CO
My first thought was fuel, the residue is not "greasy" like you usually see with oil in a combustion chamber. I think Al is probably right tho, for those front cylinders to be that much different than the others as far as fuel distribution, would really be hard to explain. I will comment more after I get into it--
Re: Odd Exhaust Port Coloring [Re: reknapp52] #1530034
11/08/13 12:09 PM
11/08/13 12:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
This is typical of manifolds that have poor fuel distribution.The 4 corners tend to run richer and even the plugs show more color at the corners.We seen this on Indy manifolds and had to cut back the runners to equalize the fuel all cylinders.
