Re: Stripping paint from plastic dash bezels
[Re: ScottSmith_Harms]
#1529970
11/08/13 08:23 AM
11/08/13 08:23 AM
Posts: 892 MA
steve70
MA
Brake fluid works great for stripping the paint and won't harm the plastic.
1970 Challenger T/A 4 speed
[Re: steve70]
#1529971
11/08/13 01:14 PM
11/08/13 01:14 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
i used oven off,it has to be the yellow can.
[Re: CSK]
#1529972
11/08/13 04:39 PM
11/08/13 04:39 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Be careful with oven cleaner, it melts most paint but will also melt the plastic if left on too long
[Re: Sixpak]
#1529973
11/08/13 05:20 PM
11/08/13 05:20 PM
Posts: 4,322 St. Louis, Mo
318 Stroker
St. Louis, Mo
Working on restoring an A body Rally Dash bezel that someone has already painted once. Curious what others have used to strip off paint from plastic without melting the plastic. Seem to recall modelers using brake fluid to strip paint from car models. No idea what type of paint was used on this bezel - enamel, lacquer, etc.
I re-did the plastic bezel for the heater and a/c controls on my Challenger. I used Testors brush cleaner to clean the old paint off, and Testors white model paint to re-do the letters. The brush cleaner worked great, with no harm to the plastic.
