Hi Chargercrazed,
The stamped number on the barrel is kind of hard to read due to the pitting. It seems to be 2095150 with a date code of 148. I will say this. When I took everything apart, it appears to have never been apart or rebuilt before as the aluminum housing has never been bead blasted and still has the smooth green sand cast finish to it. Also, the aluminum housing date coding coincides with the date coding on the barrel. Judging by how dried up the grease was inside this unit, I would feel very safe in saying that this was an original, unmolested or rebuilt starter.
