Ok, I almost feel embarassed asking what should be a simple noob question, but I'm confused so here goes.
I bought a 318 and trans out of a buddies car and I'm trying to find out what it came out of. Based on the casting number(s), I'm guessing a 1987 ish pickup or van.
The block casting # is 4387580 318 7 and the casting date is 8-28-86 as best as I can tell. It has a flat tappet cam and the "302" head castings. The stamping on the block by the timing cover is : 31809041220.
So now part two of my question. I want to go through this engine and freshen it up before I drop it into my Dart. I always thought most 318 (LA) engines were pretty much the same with a few exceptions such as cam and compression. When I try to look up an overhaul kit at Summit for example there are at least a half dozen different overhaul kits (not including differneces based on over or undersize components)for the 318 for 1970 through the late 80's. To bring this question full circle, what is the difference in the kits? Why cant I buy an overhaul kit (pistons, gaskets, rings and brearings) for a '71 318 and use it in my 1987 (?) 318?
Just for kicks here is the engine in question
Just wondering, thanks for looking
Scott
