overdrive for a big block #1528838
11/05/13 07:23 AM
11/05/13 07:23 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
I see summit has a tci bellhousing to adapt a big block to a 700r4 trans. Has anyone ever set a car up with one of these? The 65 new yorker is running good, but could use a little help in the milage dept.
Re: overdrive for a big block [Re: Carsavior] #1528839
11/06/13 02:23 AM
11/06/13 02:23 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Would you really disgrace your Mopar with a GM tranny?? Id get a JW bell and put it on a 518..
I am truckless..
Re: overdrive for a big block [Re: Carsavior] #1528840
11/06/13 02:43 AM
11/06/13 02:43 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
get a Gear Vendors and don't cut up your floor
Re: overdrive for a big block [Re: relax383] #1528841
11/06/13 04:28 AM
11/06/13 04:28 AM
Monroe, LA USA
Monroe, LA USA
Can't cut tbe floor. You ever see the bottom of a 65 Chrysler? Doesn't look anything like the Challenger. Would love to use the 518 if it would fit ok. Looking for the simplest way to overdrive the car without selling a kidney. I considered the gear vendor unit when I built the challenger but decided against it. Why add weight with an old tranny when you can just use a newer style trans without the added weight. Besides, I already have a 700r4 sitting on a shelf in the back of the shop.
Re: overdrive for a big block [Re: Carsavior] #1528842
11/06/13 05:02 AM
11/06/13 05:02 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I think you are on the right track with the GM trans and I hate to say it. I had been planning to put a 518 in my truck, but after tonight's MU meeting and the discussion with Pat Blais, I think I will stick with the 727 and go with taller tires to get the same effect at less cost
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: overdrive for a big block [Re: Carsavior] #1528843
11/06/13 10:09 AM
11/06/13 10:09 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
As long as it is prepped for the type of duty you will give it (weight/power), should be fine. 700r4 is weak from the factory but I think the aftermarket units use performance parts in all the critical areas
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: overdrive for a big block [Re: 340SHORTY] #1528844
11/06/13 11:53 AM
11/06/13 11:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Easier said than done , I think there is a long wait time right now on JW bells .
Re: overdrive for a big block [Re: JohnRR] #1528845
11/06/13 02:02 PM
11/06/13 02:02 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Just talked with JW and was told most likely by xmas.
