Can't get any Heat #152865
11/18/08 01:29 PM
11/18/08 01:29 PM
Gulf Coast of Florida
Russ Offline OP
super gas
Russ  Offline OP
super gas
My 96 Ram truck just blows luke warm when I crank up the heater,any Ideas?
the radiator and hoses were replaced this past summer
2001 Durango 5.9 Magnum 99 Durango 5.9 Magnum Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9 WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me. GO BUCKS!!!! Go GATORS!!!!
Re: Can't get any Heat [Re: Russ] #152866
11/18/08 01:32 PM
11/18/08 01:32 PM
thermostat
Re: Can't get any Heat [Re: Russ] #152867
11/18/08 01:33 PM
11/18/08 01:33 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
plugged heater core possibly
Re: Can't get any Heat [Re: RapidRobert] #152868
11/18/08 01:33 PM
11/18/08 01:33 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Replaced It with the new hoses
Re: Can't get any Heat [Re: 340dart4spd ] #152869
11/18/08 01:34 PM
11/18/08 01:34 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I second the Thermostat
Re: Can't get any Heat [Re: 340dart4spd ] #152870
11/18/08 01:34 PM
11/18/08 01:34 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Hmmm,any way to tell?
Re: Can't get any Heat [Re: 340dart4spd ] #152871
11/18/08 01:35 PM
11/18/08 01:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
don't forget the temp. control valve in the heater hose, might not be opening all the way.
Re: Can't get any Heat [Re: bboogieart] #152872
11/18/08 01:36 PM
11/18/08 01:36 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
I'll have to look at that
Re: Can't get any Heat [Re: Russ] #152873
11/18/08 01:52 PM
11/18/08 01:52 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Check your temp gauge to see if the temp come up to correct temperature.
Use a temp gun if needed.
Check both lines leading into and out of the heater core. Both should be hot when the heater is on 'hot' If they are not both hot, water is not flowing thru. Check the heater control valve.
Re: Can't get any Heat [Re: Russ] #152874
11/18/08 02:48 PM
11/18/08 02:48 PM
IMGTX Offline
IMGTX  Offline
Start with the coolant level. Low coolant can cause the heater core to run dry and then, no heat. It happens alot.
You may never even know it's low since it may not be overheating. Remember a truck's cooling systems has extra capacity for the extra loads they carry.
Re: Can't get any Heat [Re: HealthServices] #152875
11/18/08 04:17 PM
11/18/08 04:17 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Temps are running normal,and the system Is full
Re: Can't get any Heat [Re: Russ] #152876
11/18/08 04:22 PM
11/18/08 04:22 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
*Low Coolant Level
*Air lock in the heater core
*Plugged heater core
*Stuck/sticking/fauly blend door or heater control valve (coolant)
*Thermostat
First thing to do is make sure the cooling system is full. Put the truck on an incline and let it warm up with the heater on full the entire time..running it without the cap may help as well (just be ready to put it on when the thermostat opens up). You may find some air works out and you gain your heat back. That is a very common occurance in german vehicles atleast.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Can't get any Heat [Re: Russ] #152877
11/18/08 05:40 PM
11/18/08 05:40 PM
So Cal
So Cal
So what was the temp going into and out of the firewall on the heater hoses.
If it is hot going into and out of then look at the air blend door. It's under the dash.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Can't get any Heat [Re: Russ] #152878
11/19/08 01:39 AM
11/19/08 01:39 AM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
If by chance the hoses to the heater core were "switched", that can cause no heat or very little.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: Can't get any Heat [Re: bboogieart] #152879
11/20/08 02:24 AM
11/20/08 02:24 AM
Troy, TX
74Sport Offline
74Sport  Offline
Troy, TX
I second the water control valve. Is yours actuated by vacuum or a cable? You might have a bad diaphram or vacuum leak.
Jerry
There's a difference between ignorance and stupidity. Ignorance is not knowing any better. Stupidity is knowing, yet doing it anyway.
Re: Can't get any Heat [Re: 74Sport] #152880
11/20/08 02:51 AM
11/20/08 02:51 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
My 93 Cummins is luke cold!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
