69 coronet/bee parts interchange??? #1528488
11/04/13 01:55 PM
11/04/13 01:55 PM
KS.
HairOtheDog Offline OP
KS.
I've been searching the forums and "on-the-line" and can't find a definitive parts x reference between the 68-69 coronet/bee and also the 68-69 Sat./RR.
(I'm picking up a 69 coronet 500 that needs parts and would like to know parts options.)
Can someone direct me to a location that has that info?
(I'm mainly looking at sheet metal and glass, I know there's some large differences between grills, marker lights, taillights etc. (ex. 68. Coronet vent windows fit in a 69 coronet?))
Re: 69 coronet/bee parts interchange??? [Re: HairOtheDog] #1528489
11/04/13 05:12 PM
11/04/13 05:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are at the source ... ...
68/ 69 coronet body many parts interchange, some may not be exact as there were minor changes but the parts will still work, like the doors, 68 is slightly different than 69 but they will work. Doors from a 68-70 Plymouth B body will also work on your Coronet, but not Charger doors the outer skin is different.
Glass in the same, though there is a difference between coupe and hardtop, and obviously 4 door and convertible.
As far as sheet metal goes things between 68 and 69 Coronet can be made to work , but the extra work involved you might as well stick to 69 sheet metal , like fenders and quarters . The hood will interchange, 69 has a piece added to the front lip for the grille change. Trunk lids and tail panels are not the same. Bumpers are the same 68/69 Coronet.
Outer sheet metal/bumpers/trim on 68-69 Plymouth is different, many interior parts will interchange between Plymouth and Dodge, seat patterns/door panels are different though.
Re: 69 coronet/bee parts interchange??? [Re: JohnRR] #1528490
11/04/13 08:13 PM
11/04/13 08:13 PM
KS.
KS.
Thanks a bunch John!
Good info right there, copied and saved-
Are The vent windows are the same on 68-69 2 door and 4 door coronets?
Re: 69 coronet/bee parts interchange??? [Re: HairOtheDog] #1528491
11/04/13 08:21 PM
11/04/13 08:21 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
nope
the 4dr windshield is at a differant angle.
Re: 69 coronet/bee parts interchange??? [Re: flypaper] #1528492
11/04/13 09:49 PM
11/04/13 09:49 PM
KS.
KS.
nope
Dang
thanks, I didn't see that coming I thought they'd be the same,
you just saved me some $$$,
I was just about to bid on a pair of vent windows from a 69 coronet 4dr on EBag!
Thanks for the save!
