Re: When are Pro gears needed in dana 60
[Re: sixty9bee]
#1528331
11/04/13 12:03 AM
11/04/13 12:03 AM
Posts: 1,301 Penna
70satelliteguy
Penna
"Pro gears were not recommended by strange " That's funny. They recommended and installed pro gears for my Dana 60 unit that I purchased from them years ago. My car is 3600 lbs. trans brake with low 1.30 60 ft. times.Car runs mid 9's on motor and high 8's on juice.I run a 4:10 ratio and Never had any problems yet!Hundreds of passes! Mike
[Re: sixty9bee]
#1528332
11/04/13 12:08 AM
11/04/13 12:08 AM
Posts: 9,863 MI, usa
dvw
MI, usa
Strange told me I didn't need them either. I run standard US Gear 4.10. 90 passes so far. Foot brake 1.32, 9.25,147 @3340 lbs. I was told standard gears would be fine. I can tell you I experimented with the pattern when setting them up. By adding .010" additional pinion cup shim the pattern covered an area nearly twice as wide on the face of the tooth. I thought it looked pretty decent to start with but it kept getting a wider contact patch as I went. I also made sure I had proper pinion and side bearing pre-load. Doug
[Re: Sammy]
#1528336
11/04/13 12:40 PM
11/04/13 12:40 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
If you already have a street gear of the right ratio in your car run it until it breaks.If it breaks a stock gear,then you will know you need a Pro Gear.If have neither go ahead and buy a Pro Gear at the start.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1528337
11/04/13 02:08 PM
11/04/13 02:08 PM
dartman366
Mt. Vernon, Ohio
after breaking my 8.75 I built a dana 60 and automatically went with a pro gear since I was running a T brake, been in the car for 7-8 years now 5 years with the current motor, pulled the cover last winter during my back half job and they looked like new, I have been told that a pro gear has a softer heat treat to with stand the shock but would wear quicker, so far I haven't noticed any excessive wear.
[Re: dartman366]
#1528338
11/04/13 06:53 PM
11/04/13 06:53 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Ran 9.0's at 3,400 lbs for years with a street gear and aluminum spool. Had 1.27 60 fts. Added a bunch of tire and dropped some weight. Started breaking street gears. Installed Pro gears then started breaking 727 planetaries. The 60 ft was no better after solving the gear problem it is simply how hard the tire hooks.
Leon
[Re: dartman366]
#1528339
11/05/13 01:48 AM
11/05/13 01:48 AM
Posts: 170 renton , washington
perfmachst
renton , washington
hi, the pro gears are made out of 9310 material, the street gears are 8620 material. its in their catalog. you can soften up a 8620 set to make them last longer. it's an old jr.stocker trick from the 1960/1970's. all there were 8620 gears. lots of breakage.
