Re: 413 stroker? supercharged 6-71
[Re: kams]
#1528307
11/03/13 10:20 PM
11/03/13 10:20 PM
RapidRobert
1.09" on the pin OD/rod small end ID
[Re: kams]
#1528308
11/04/13 12:35 AM
11/04/13 12:35 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
I bought a 383 yesterday for the stock pistons, for my 413 stroker build. What is the piston pin dia. on the 383 piston and 413 LY rods, as they don't look the same?
And what would be a good size cam for a blower motor lift/ duration?
Thanks, I would like to keep the motor cost udder 1200 as I am going to supercharger it for a street rod I am building.
stock 383 pistons are .070 bigger in diameter and shorter in compression hieght than stock 413 pistons are As far as the cam selection you should ask the blower shop your buying the blower parts from Which type supercharger are you going to use, Roots, centrifugal or srew type?
