E body drum brakes....still not right #1528068
11/03/13 02:57 PM
11/03/13 02:57 PM
S.florida
Jupiter331 Offline OP
S.florida
Thanks for your help on this post in the past. 70 Challenger, master cylinder was empty after 6 months storage, no sign of leaks, manual factory drums.could not get all wheels to bleed so I replaced m/c, bench bled. Replaced rubber hoses, replaced wheel cylinders. Tried bleeding with a vacume pump but the pump would not draw fluid from all the wheels. Tried gravity bleed didnt work. Tried the good old fashioned pump the pedal. Seemed like they bled. Test drive, exactly the same as when I bled the original system. Firm pedal, step on the brakes and the steering wheel jerks from side to side and one front tire begins to skid. Car stops fine however you practically loose controll. The brakes worked fine for years when I parked the car. Bled it in the past with no problems. Dont know what yo do at this point. Ive tried everything I know.....any help woild be greatly appreciated.
Re: E body drum brakes....still not right [Re: Jupiter331] #1528069
11/03/13 03:57 PM
11/03/13 03:57 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Seems it's only the front wheels that are bothersome.
?fluid soaked linings? Front (shorter)
lining) shoe and rear shoe swapped??
Re: E body drum brakes....still not right [Re: Jupiter331] #1528070
11/03/13 06:15 PM
11/03/13 06:15 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sounds like the lines are blocked. at this point i would go to a brake shop and have the system bleed out on a power bleeder to flush out all the old fluid and hopefully any build up inside the lines.
Re: E body drum brakes....still not right [Re: mikemee1331] #1528071
11/03/13 06:32 PM
11/03/13 06:32 PM
If it's pulling to the pass side then the DR side ain't doing it's job for whatever reason (& vice versa). Could be the linings ain't spooned up far enough on the offending side but you did mention blockage issues. I'd undo the particular lines & blow em out if I was sure there was inadequate psi at the bad corner
Re: E body drum brakes....still not right [Re: RapidRobert] #1528072
11/03/13 10:59 PM
11/03/13 10:59 PM
IN
ahy Offline
ahy  Offline
IN
Rust on the drums can make them grab. Not sure its your problem but it may be. Some careful stops from speed on a lonely highway will clean them up.
