Fixing AC to work on new juice #1527423
11/02/13 03:00 PM
11/02/13 03:00 PM
Stockholm, Sweden
MrSixpack Offline OP
Stockholm, Sweden
My 66 Chrysler 300 has a none working AC system.
And my goal is to fix it during this winter.
Is it possible to make it work with the new type of freon?
Where can I get a rebuild kit for the system.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Fixing AC to work on new juice [Re: MrSixpack] #1527424
11/03/13 10:54 AM
11/03/13 10:54 AM
You might see if you can retrieve some past threads regarding this. From what I've gathered R12 is no longer being manufactured tho there are tons left. As you know it (the single cans) is available on eBay/CL tho it is pricey. To changeover I think you need the new type "barrier" hoses, the reciever/drier needs to be changed to the new type, the valve at the firewall needs to be changed, the oil in the compressor needs to be changed to the new type, new type of O rings in the hoses/fittings then vac pump the system empty which is std procedure then add the new stuff & I think you go by weight & use less of the new type of freon. Some say it dont cool as well as R12 & others are happy with it. dont remember if a larger evaporator (next to rad) is needed (or recommended). I'd wanna check the system for leaks in the process so I dont have to mess with it again. Might be more to it than this but here's a BTT for ya. EDIT A '66 "300" would have a monstrous condensor so you're good there
Re: Fixing AC to work on new juice [Re: MrSixpack] #1527425
11/03/13 11:44 AM
11/03/13 11:44 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have converted quite a few cars to 134 and all I have done is changed the fittings and evacuate then charge with 134.
All the hype about changing O-rings and special hoses and receiver/drier replacement is not necessary.
Some of the newer kits come with improved oil in the can so it is added during the recharge.
Just my after 30 years in the dealership
Gus
64 Plymouth Savoy
Dana 60
Re: Fixing AC to work on new juice [Re: fourgearsavoy] #1527426
11/03/13 01:53 PM
11/03/13 01:53 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Gus
x2
The little old lady from Pasadena is back!
Re: Fixing AC to work on new juice [Re: Barnstorm] #1527427
11/03/13 04:24 PM
11/03/13 04:24 PM
Stockholm, Sweden
Stockholm, Sweden
A BIG thank you
1968 Mini Cooper
Re: Fixing AC to work on new juice [Re: MrSixpack] #1527428
11/03/13 08:12 PM
11/03/13 08:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I converted my 87 Diplomat over, with the C171 compressor. I was not real impressed with it's ability to handle the Texas heat.
Don't be the exception.
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527429
11/04/13 08:10 PM
11/04/13 08:10 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
you're right about tons of it....but it's still being made by Dupont down in Ingleside, Texas. I see rail cars full of R12 every day I drive over there leaving the plant.
R12 is still used, just not in Automotive Cooling systems.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Fixing AC to work on new juice [Re: shanker] #1527430
11/04/13 09:50 PM
11/04/13 09:50 PM
Alright, OK if R12 cools the best & it is still available & will be for quite awhile would it not be a smart move to keep a system on R12 rather than converting?
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527431
11/05/13 12:29 AM
11/05/13 12:29 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Well, a charge of R12 for your car will run >$ 500 if it leaks, you get to do it again. I too have changed many system's over. Fix the leaks, new orings, Fittings,new receiver/dryer and evac and fill. Need to replace the receiver to avoid contaminants that will coorode your compressor.
Astrobuf
So, are you really a Rocket Scientist?
Re: Fixing AC to work on new juice [Re: astrobuf] #1527432
11/05/13 10:52 AM
11/05/13 10:52 AM
that answers that Q
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527433
11/05/13 03:59 PM
11/05/13 03:59 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
that answers that Q
I guess someone hasn't checked prices of R12 on ebay...it's gone down ALOT in pricing in the past several years.
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527434
11/05/13 04:57 PM
11/05/13 04:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, yes, yes. R-12 isn't that expensive and no conversion is necessary. If it leaks with R-12 it'll leak faster with R-134.
Re: Fixing AC to work on new juice [Re: John_Kunkel] #1527435
11/05/13 05:53 PM
11/05/13 05:53 PM
John you are the man & alright I will stay with R12 when I get to that point (adding AC to my 65 dart)
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527436
11/05/13 06:06 PM
11/05/13 06:06 PM
BDW Offline
BDW  Offline
Why, although it might not be as expensive as you thought it will still be at least 5x more.
You want to bid on freon on eBay for $25 a can or go to local store for $5?
Re: Fixing AC to work on new juice [Re: BDW] #1527437
11/05/13 08:43 PM
11/05/13 08:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The R-134 molecule is considerably smaller than the R-12 molecule which simply means it will leak out faster and most R-12 systems are defunct because the refrigerant leaked out. In the long run the cheaper R-134 might wind up costing as much as the R-12 for the same length of service.
Re: Fixing AC to work on new juice [Re: RapidRobert] #1527438
11/06/13 02:45 AM
11/06/13 02:45 AM
MN
astrobuf Offline
astrobuf  Offline
MN
It is illegal for you to purchase and install R12.
It is a federal offense for an unlicensed individual to do so.
I see folks are selling on ebay and using an illegal dodge to do so for now. Doubtful this will be an option in a few years when you need to reload.
If you dont know what you are doing, it is doubtful you will be able to correctly load the 12oz cans of r12 you buy illegally. You will end up paying someone to do the job right sooner or later.
Re: Fixing AC to work on new juice [Re: astrobuf] #1527439
11/06/13 02:49 AM
11/06/13 02:49 AM
Yeah I definitely dont know my way around AC systems. I'd (likely) have my maintenence man buddy do it with his R12 gauge set
Re: Fixing AC to work on new juice [Re: astrobuf] #1527440
11/06/13 04:07 PM
11/06/13 04:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No it isn't, I have a 509 license and they're easy to get online. BTW, it's also illegal to go 66 mph in a 65 zone....how many here are guilty?
"Shunt's Law" applies here (If you don't know what you're doing you shunt mess with it), same applies to all automotive operations.
"Loading" cans of R-12 is no different than "loading" cans of R-134 and take notice of the DIY charging kits available in every box store.
Re: Fixing AC to work on new juice [Re: John_Kunkel] #1527441
11/06/13 04:57 PM
11/06/13 04:57 PM
Stockholm, Sweden
Stockholm, Sweden
We pressure tested the system to day and it's leaking from the input shaft on the compressor.
So I need to rebuild the compressor, but who has parts for it?
1968 Mini Cooper
Re: Fixing AC to work on new juice [Re: MrSixpack] #1527442
11/07/13 02:16 AM
11/07/13 02:16 AM
X2, If I have any leaks (at $25 a can) I want the system confirmed sealed up tight before I proceed
