B-body X E-body big block HP manifolds #1527413
11/02/13 01:10 PM
11/02/13 01:10 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
I friend gave me a set of 73 big block b-body hp exhaust manifolds to use on my 383 71 challenger.
1) Are BB b-body manifold same as e-body?
2) Has some visual diferences between 71 hp exhaust and 73 hp exaust?
I don't care about date and casting numbers.
manifolds:
Re: B-body X E-body big block HP manifolds [Re: v8punch] #1527414
11/02/13 02:54 PM
11/02/13 02:54 PM
Those are the good HP manifolds. www.bigblockdart.com would likely have some more part #'s/info for you
Re: B-body X E-body big block HP manifolds [Re: RapidRobert] #1527415
11/02/13 07:16 PM
11/02/13 07:16 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Thank's Robert, I'll try to find more info there.
Re: B-body X E-body big block HP manifolds [Re: v8punch] #1527416
11/03/13 09:11 AM
11/03/13 09:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only issue you will potentially have is the clocking of the flange on the passenger side manifold , it may be different than the 71 manifold , if the exhaust you run has a welded flange it will not match up.
Re: B-body X E-body big block HP manifolds [Re: JohnRR] #1527417
11/03/13 09:28 PM
11/03/13 09:28 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
The clocking issue is not a problem if you run TTI. Tell them the numbers on the manifold and they will dial it in with the correct clocking on the flanges.
Other vendors should be able to do the same.
Re: B-body X E-body big block HP manifolds [Re: PHJ426] #1527418
11/03/13 09:32 PM
11/03/13 09:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is true but it needed to be said ...
Re: B-body X E-body big block HP manifolds [Re: JohnRR] #1527419
11/03/13 09:53 PM
11/03/13 09:53 PM
With double R, That was pertinent info that needed to be shared
