Billet drum comparison #1527361
11/02/13 11:17 AM
11/02/13 11:17 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I lost a solid .1 from switching from a billet steel A & A drum to a billet aluminum drum
Can this really happen?
No other changes were made and the 727 torqueflite is fresh
Re: Billet drum comparison [Re: Sammy] #1527362
11/02/13 02:03 PM
11/02/13 02:03 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I went from a stock hipo rebuild type 727 to a full roller with aluminum drum and saw nothing.
Others have said they didn't see anything either with such changes.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Billet drum comparison [Re: B3422W5] #1527363
11/02/13 02:09 PM
11/02/13 02:09 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I desperately want to see the difference between a 46RE and a rollerized 727.... I've heard it's as much as 4 full tenths.
Re: Billet drum comparison [Re: Sammy] #1527364
11/02/13 03:54 PM
11/02/13 03:54 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Only built one myself but I wonder if clutch/band materials &/or clearances could have caused the trans to be a little tight? Or maybe the line pressure is off from where it was? Just a little brainstorming.
Re: Billet drum comparison [Re: 80fbody] #1527365
11/02/13 04:18 PM
11/02/13 04:18 PM
K
KOS Offline
KOS  Offline
K
just did the exact same switch and lost 2tenths 2mph........i was wondering the exact same thing.....the alum drum is 6lbs lighter than the billet steel one how in hell can the car slow down???the car 60ft is down .5 and i just did a converter change to rule out the vert will find out tm im tryin to get back out weather permitting.
Re: Billet drum comparison [Re: KOS] #1527366
11/02/13 04:48 PM
11/02/13 04:48 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Band too tight dragging on the drum?
I know we switched from an aluminum to a billet in my Dad's NSS car this summer, and the car slowed down ~.08 from the change.
Aluminum drum should most definitely help, not hurt.
Re: Billet drum comparison [Re: Sammy] #1527367
11/02/13 05:16 PM
11/02/13 05:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
unless you did the swap on the same day same conditions it would be hard to compare.
Re: Billet drum comparison [Re: Quicktree] #1527368
11/02/13 05:48 PM
11/02/13 05:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a drop of 10 on the barometer for me is almost a drop.08 of e.t. on the same tune.
Re: Billet drum comparison [Re: Sammy] #1527369
11/02/13 06:20 PM
11/02/13 06:20 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I will lose .1 on a rebuild.. starts coming back after 8 or 10 runs if the trans is working fine just run it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Billet drum comparison [Re: WHITEDART] #1527370
11/02/13 06:25 PM
11/02/13 06:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Barring nothing else changed anywhere. The only thing I could possibly think of is loss of coefficient of friction between the K/D band and the drum. A lighter part should never slow the car down. We'll see I have plenty of data with my 10.2 lb A&A steel drum. I'm changing back to aluminum for next year.
Doug
Re: Billet drum comparison [Re: Quicktree] #1527371
11/02/13 07:02 PM
11/02/13 07:02 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
This is over the course of the whole racing season. Just never 60 footed where it was and to the 1/8th off by .05 and 2 mph and a full tenth at the big end.
Was hoping for a new best with the good air only to come up short.
