Another B+M shifter cable length, 3 foot?
#1526915
11/01/13 01:38 PM
11/01/13 01:38 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
71 Duster street machine, 340/W2 with TTi 1 7/8 step headers with full exhasut, 904, Summit deep pan with thick flange, B+M Pro Ratchet shifter with 5 foot cable, mini starter.
Shifter was originally installed when the car had a bench seat but that was removed recently for buckets. During seat mockup, the shifter got moved farther back on the tunnel because it was more comfortable with the new seat position, thus altering the effective length of the cable. It was initially looped around the starter and was tied to the trans support brackets. It seemed to be OK there, not burned or anything. The hole in the tunnel where the cable goes through the floor is pretty far up towards the firewall.
But now since it's moved back a little, there is not enough length to loop it around the starter anymore - it basically sits right between where the headers and starter is and right on the header tube. Not good.
Clearly I could drill another hole and move the point where the cable goes through the floor but that doesn't really solve the problem of the extra length.
Before I start messing with it, I wanted to see if anyone had success with a 3 foot cable? Seems to me the shorter one could seem to solve the issue of all the extra length and where to put it so it doesn't melt or bind. The threaded boss where the kick down linkage used to bolt to looks like a perfect place for a clamp.
I have read through several posts on here about these cables, seems like a common problem with routing. I didn't see if anyone solved the issue with the shorter cable though. Just for reference, I have a big ground strap on the passenger side and heat shielding.
Thanks for any input.
- Greg
'71 Duster '72 Challenger '17 Ram 1500
Re: Another B+M shifter cable length, 3 foot?
[Re: RMCHRGR]
#1526916
11/01/13 01:43 PM
11/01/13 01:43 PM
dartman366
Mt. Vernon, Ohio
Take your cable off and measure it, then get one that is a next size longer to fit your needs, I think they come in 3,4,5 foot lengths, I had run into this problem when I first installed mine and just bought a longer cable to fit.
[Re: RMCHRGR]
#1526919
11/01/13 05:10 PM
11/01/13 05:10 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
I thought the b&m shifter cables attached to trans from the front, so you had to go towards engine then loop (the longer the better)around to tranny. i went with turbo/action because cable attached from the rear
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: RMCHRGR]
#1526923
11/02/13 12:01 AM
11/02/13 12:01 AM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
Route around the passenger side around the pan looping under the bell housing. I have a dei reflective heat shield on mine and have it strapped to the pan bolts.
How long is your cable, 5 foot?
I'm guessing there is no binding where it comes back up from under the pan and goes to the lever?
It's the factory cable that came with the shifter so it should be five foot I would imagine. I have never had a problem with it routed this way for about 10 years now. I think the heat shield is a must which ever way you route it. Cables get expensive fast with headers! The shield I use slips over the cable about 3 foot or so I would imagine.
[Re: RMCHRGR]
#1526924
11/02/13 01:35 AM
11/02/13 01:35 AM
dartman366
Mt. Vernon, Ohio
So you're saying to get the longer one? I have the 5 foot one.
Wouldn't it be better to have less length to deal with?
only if you can do it and not put the cable in a sharp bend.
[Re: dartman366]
#1526925
11/02/13 10:36 AM
11/02/13 10:36 AM
RMCHRGR
Spahn Ranch
OK, thanks for the replies. I might go out and fight with it to see what I can come up with.
Still wondering though if anyone has used the 3 foot cable with success?
[Re: dizuster]
#1526928
11/02/13 10:33 PM
11/02/13 10:33 PM
Posts: 635 mississippi
bentwheel43
mississippi
I did too, but I ran mine through a 5/8 heater hose that was 10 years ago--- I forgot about that. It works!! Still working!!
Section 8 Racing We are nuts about racing.
[Re: bentwheel43]
#1526929
11/03/13 11:07 AM
11/03/13 11:07 AM
RMCHRGR
Spahn Ranch
So I guess the consensus is to stay with the 5 foot or get a longer one?
If its looped around the bell from the pass. side clearly a longer one would be good. Guess I just wasn't sure if the 5 foot would be long enough to do it that way.
But based on what barracuda7199 said in his reply it seems to work with the 5 foot cable.
[Re: RMCHRGR]
#1526930
11/03/13 05:40 PM
11/03/13 05:40 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
I run the 3' cable on my Satellite . melted several 5' cables and even a 4' one . I now also use a aluminium waffle type heat shield between the headers and cable . haven't had an issue since, maybe 3 years . I still carry a spare in the boot all the time . Mine is a daily driver / racer
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: RMCHRGR]
#1526932
11/04/13 10:03 PM
11/04/13 10:03 PM
RMCHRGR
Spahn Ranch
So I was able to make the 5 foot cable work.
I drilled a new hole farther back on the trans tunnel so the cable was closer to the shifter. It goes towards the passenger side and loops back around the bell to the driver's side. Seems to work OK, possibly better than before since it has a more gentle loop now.
I wrapped it with heat shield tape where it gets near the exhaust but its no closer than it was before it was moved and it never burned.
Thanks for all the replies, glad I didn't spend the coin on a new cable.
