Is a horn relay needed? 69RR rewiring ? #152691
11/17/08 10:11 PM
11/17/08 10:11 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'm rewiring my 69 RR and wondered if I need to add the horn relay back into the wiring. I'm using a Ron Francis wiring kit and there is no mention of using a horn relay.
Re: Is a horn relay needed? 69RR rewiring ? [Re: NV69B7RR] #152692
11/17/08 10:17 PM
11/17/08 10:17 PM
I'm not familiar with any of these aftermarket wiring kits, but I certainly would wire in a horn relay. Horns draw a considerable amount of current, and depending on the relatively light wiring, and relatively poor contact through the horn button and slip rings is pretty dicey
Re: Is a horn relay needed? 69RR rewiring ? #152693
11/18/08 02:51 AM
11/18/08 02:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It is not current that is the issue with horns, it is polarity. The horn button connects a ground, BUT the horns are already grounded. The horn relay basically converts a negative to a positive.
