92 5.2 L Questions and swap for 78 318 D100
#1526797
11/01/13 09:59 AM
11/01/13 09:59 AM
Posts: 4,366 Cleveland, Ohio
northcoastmopar
Cleveland, Ohio
For sale locally is a '92 5.2L and trans out of a B250. Suposedly with 85k miles, engine and trans pulled because of rusted frame. Questions ---- I assume this is a magnum engine? If so, how hard/easy to swap into my 78 D100 and replace the asthmatic 318LA that's in there now? Supposedly the B250 engine comes with complete engine harness. Is there any value for the B250 trans? I have no idea what it is. Don't know anything about trans newer than 727 or 904. If the swap is not terribly hard/expensive what is a fair price for the engine by itself or the engine/trans combo? He is asking $500 but willing to take offers. Wants to get rid of it seems. Thanks in advance! ![](/ubbthreads/images/graemlins/wave.gif)
Re: 92 5.2 L Questions and swap for 78 318 D100
[Re: northcoastmopar]
#1526798
11/01/13 10:27 AM
11/01/13 10:27 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
92 was first year of Magnum 5.2, 93 was first year for Magnum 5.9
should be a Magnum.
but it'll be OBD-I which doesn't have any aftermarket support for tuning the engine if you make upgrades from stock, and pretty sure it'd be TBI as well. If you wanted to swap the truck to EFI, you'd be better off to go OBD-II. It's MPFI and has tuning options.
but, $500 for a complete engine/trans is not a bad price. not great either...about average for a used "junk 318" that nobody wants.
**Photobucket sucks**
[Re: BulletBob]
#1526800
11/01/13 05:06 PM
11/01/13 05:06 PM
northcoastmopar
Cleveland, Ohio
All Magnums are MPFI If you want to do the swap with FI get all of the wiring including the dash that way you have a chance of everything working the way it is supposed to
Do you have A/C that you want to use? That makes a difference on which direction your swap has to go & how much $$$$ it costs
I don't believe the dash and wiring are available..my 78 D100 does have air, not working at this time but it's all in place..I would like to keep that system in place.
[Re: BulletBob]
#1526805
11/01/13 10:25 PM
11/01/13 10:25 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
The transmission should be a 518 which is an overdrive version of the 727.
It will be a lockup, with overdirve, and its not terribly difficult to make that work using the PATC kit that uses some pressure switches, and a vacuum switch to control both.
You would need to have the tailshaft housing removed for it to bolt to your transfer case. and would also need to get driveshafts from a 92-93 W150 donor, or have your rear shaft shortened, and a longer front shaft made.
But, the benefits of the overdrive really show up at the gas pump.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1526808
11/04/13 11:36 AM
11/04/13 11:36 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
my 92 518 is a 2wire.
Moparlee
