Federal PS pump for a 440?? #1526693
10/31/13 08:45 PM
10/31/13 08:45 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
Were federal PS pumps used on the 440's? or do I need to get something else....I have one I took off a 360?? Thanks
Finally Done....BEERS!!!
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526694
10/31/13 08:55 PM
10/31/13 08:55 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
My '68 GTX uses one....I got a rebuilt one thru our Lordco Auto in Canada. Hard to find now though.....
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526695
10/31/13 10:06 PM
10/31/13 10:06 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
You did not specify a year, however Federal pumps (as well as Saginaw pumps) were used on '68-'69 B bodies with 318, 383 and 440 engines. They were probably on other years/models also, but I am only familiar with '68/69 B bodies.
If you are using one from a 360, I would think the mounting brackets would be the problem, not the pump itself.
Re: Federal PS pump for a 440?? [Re: moparfan53] #1526696
10/31/13 10:24 PM
10/31/13 10:24 PM
IN
ahy Offline
ahy  Offline
IN
SB and BB pulley spacing is different... at least with Saginaw pumps. The Saginaw is considered the better pump and is readily available (JY, parts store, new aftermarket). If its not a 100 point resto I'd consider getting a Saginaw pump and matching brackets. Bouchillon can probably fix you up with the brackets. They also offer a pulley spacer kit to provide correct alignment when a SB pump is used on a BB. Its for Saginaw pumps... it may work for Federal.
Re: Federal PS pump for a 440?? [Re: ahy] #1526697
11/01/13 10:17 PM
11/01/13 10:17 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Changing around power steering pumps can be a big pain. All the brackets are different from slant 6 to sb to big block and all the pulley's are different as well. It's never a simple swap.
Rocket Restorations
Re: Federal PS pump for a 440?? [Re: ahy] #1526698
11/01/13 10:17 PM
11/01/13 10:17 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I have one on my '67 300 that looks to be OE AFAIK.
I need to fix it, too, as the pump body to reservoir seal is leaking
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526699
11/02/13 07:56 AM
11/02/13 07:56 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
The U-code '73 Polara 440 CHP cruiser has a Federal pump.
Steve
Someday I'll have another C-body.
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526700
11/02/13 10:39 AM
11/02/13 10:39 AM
Fairfield, Ohio
Fairfield, Ohio
Thanks for all the info....found a few places to buy reconditioned pumps or rebuild kits and can get big block brackets on ebay.......
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526701
11/02/13 11:33 AM
11/02/13 11:33 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Overall, the Saginaw is a better pump, plus, it is much easier to reduce the line pressure for improved "road feel" - see:
MA - Pump It Down article
Brackets, pulleys, and hoses are no problem, widely available.
Rick
Re: Federal PS pump for a 440?? [Re: Rick_Ehrenberg] #1526702
11/02/13 12:00 PM
11/02/13 12:00 PM
Fairfield, Ohio
Fairfield, Ohio
printing this out....may just decide to buy reconditioned Saginaw and brackets....
Re: Federal PS pump for a 440?? [Re: holtzdog55] #1526703
11/02/13 11:55 PM
11/02/13 11:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
federal pump on my 76 440.
Re: Federal PS pump for a 440?? [Re: MowP4rsn] #1526704
11/03/13 08:54 PM
11/03/13 08:54 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
that is simply an O ring gasket, take it off the car and change the O ring.
Re: Federal PS pump for a 440?? [Re: sthemi] #1526705
11/04/13 02:17 AM
11/04/13 02:17 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Thanks, I have done a rebuild in the past on a ps pump, so I know what it requires, but I no longer have the tools that I used to have, and the apt. complex I live in takes a dim view of doing repairs in the car port, not that I haven't had or done some repairs in said carport
And I think I was incorrect in my 1st post, I think I have the TRW unit, not the Federal unit
Re: Federal PS pump for a 440?? [Re: MowP4rsn] #1526706
11/04/13 09:20 AM
11/04/13 09:20 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Federal PS pump for a 440?? [Re: hemi71x] #1526707
11/05/13 12:38 AM
11/05/13 12:38 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It's easy to tell a Federal pump from the other one at least on 60's stuff. The Federal will have a block of wood jammed behind it to keep the belt tight. The bracket was so prone to breaking that the wood block should have had a Mopar part # on it.
Kevin
Re: Federal PS pump for a 440?? [Re: Twostick] #1526708
11/05/13 07:10 PM
11/05/13 07:10 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
FYI, here's a picture I took of my power steering pump and brackets from my '68 Charger R/T with a 440. John
Re: Federal PS pump for a 440?? [Re: Meangreen68] #1526709
11/18/13 12:54 AM
11/18/13 12:54 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Thanks for that image, John.
I double checked the back of the pump reservoir and made sure that it had that long indentation, which it does, so Thompson/TRW unit it is and NOT a Federal unit.
Re: Federal PS pump for a 440?? [Re: MowP4rsn] #1526710
11/18/13 03:28 PM
11/18/13 03:28 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
That is correct. They are often mistaken as being one in the same but in fact are different when it comes to the mounting bracket areas. They are interchangeable but a different reservoir can...
