3.9 Camshaft? #1526630
10/31/13 06:34 PM
10/31/13 06:34 PM
Dreaming of Idaho
U
unlucky68 Offline OP
U
Dreaming of Idaho
Just wondering if the camshafts, pushrods, and lifters between the LA 3.9 V6 (Pre-Magnum) and 3.9L Magnum can be swapped? Just brainstorming at the moment and thought of at some point replacing TBI camshaft setup with the Magnum one.
Re: 3.9 Camshaft? [Re: unlucky68] #1526631
10/31/13 06:40 PM
10/31/13 06:40 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
is the LA 3.9 a roller cam block? if so, I see no issue on swapping them. I don't know anyone that's done it, but I would imagine it's a bolt on swap.
...are the specs different enough on the Magnum to justify though? I know several Dakota guys who have had cams re-ground by delta cams for just over $100. They have several thousand miles on their reground cams and no issues.
might be a cheap way to get some more oomph for the tiny V6.
**Photobucket sucks**
Re: 3.9 Camshaft? [Re: 70Cuda383] #1526632
11/01/13 12:08 PM
11/01/13 12:08 PM
dogdays Offline
dogdays  Offline
Or Bullet cams for $125. Bullet has a huge list of hydraulic roller grinds, including several 209 degrees @50 and smaller.
R.
Re: 3.9 Camshaft? [Re: unlucky68] #1526633
11/02/13 08:17 AM
11/02/13 08:17 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
some years of LA had an extension on the cam to drive a mechanical fuel pump
Magnum 3.9 V6 cam timing
(250 degrees advertised intake duration with 31 degrees overlap)
http://dodgeram.org/tech/gas/specs/3_9v6.htm
the airflow capability of the Magnum intake port is significantly higher, around 30 cfm
Re: 3.9 Camshaft? [Re: 360view] #1526634
11/03/13 09:45 PM
11/03/13 09:45 PM
Dreaming of Idaho
U
U
Dreaming of Idaho
Thank you. Yes, it is a roller cam engine and has an electric fuel pump. I believe all 3.9s are roller cam but, the 87 still had a carburetor so it used a mechanical fuel pump. Anyways, I figure I would ask because at some point I will do a timing chain and tensioner so I have thought about the V6 Magnum camshaft since I can get one cheap but, we'll see.
