Won't start!! Why? UPDATED!!
#152605
11/17/08 08:05 PM
11/17/08 08:05 PM
Posts: 752 North of the Motor City
DartGTDan
Went out to start the Dart today, and got the dreaded "click".
Put the jumper cables on and let it charge off a running donor car for about 30 minutes. "Click"
Removed battery from the Dart and attached jumper cables from running donor car to Dart's stock cables. "Click"
Put battery back in the Dart, connected stock cables, checked battery voltage 13.5V, turn key to "start" position got the "click" and battery voltage dropped slightly, but did not go to zero.
Had trouble end of summer with a dead "right now" battery. Replaced the battery, and was good for the occasional outing (once or twice a week). Has been sitting for the last week and a half. Thought I should run it today and that is when my trouble started.
What is going on?
Re: Won't start!! Why?
[Re: DartGTDan]
#152606
11/17/08 08:15 PM
11/17/08 08:15 PM
Posts: 10,219 Someplace you aren't
SomeCarGuy
You either have corrosion or a loose cable
or
a bad relay, key switch
or
a burn wire someplace
shouldn't be too hard to figure out
I want my fair share
[Re: DartGTDan]
#152607
11/17/08 08:22 PM
11/17/08 08:22 PM
RapidRobert
dead battery or the cable ends/terminals need a good cleaning.
[Re: DartGTDan]
#152609
11/17/08 08:37 PM
11/17/08 08:37 PM
RapidRobert
Myself I would clean the dielectric grease off COMPLETELY with some brake clean & try again. You are sure the batt is good/charged? If so jump the starter from its batt terminal to the solenoid terminal down at the starter
[Re: repad]
#152611
11/17/08 08:54 PM
11/17/08 08:54 PM
You sorta' have two sections of the circuit, and you can divide the problem in half immediately
The first section is the key, and circuit feeding the key (ignition) out the bulkhead, to the starter relay (on the firewall) and down through the neutral safety switch to ground
The OTHER half of the circuit is from the battery feed, through the contacts of the (firewall) starter relay, and down to the starter relay.
BUT but but..... then last, you also have the main big battery cable to the starter "big" post
So divide the problem in half. Will it crank (turn over) if you short across the only two bare terminals on the relay?
If not, you have a problem in the big main cable to the starter, or in the starter/ solenoid itself.
#152612
11/17/08 09:34 PM
11/17/08 09:34 PM
Posts: 5,163 CT
GTX MATT
CT
Sounds like starter failure to me. Be sure the starter connections are good. If they are try jumping the solenoid first but if it doesnt work its the starter.
With ignition switch failure in my experience there isnt a click.
[Re: GTX MATT]
#152613
11/18/08 12:37 AM
11/18/08 12:37 AM
Posts: 1,647 IL
71383beep
IL
I would guess nuetral safety switch.
I have had so many go bad I just made a jumper to ground out the tranny NSS wire. You just got to be carefull to not start it in gear.
Try just a jumper from a ground to the post on the starter relay that takes the NSS wire...brown wire IIRC. If it starts the switch is the problem. Either the switch is bad or something in the tranny is a bit out of alignment when in park.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: 71383beep]
#152614
11/18/08 07:54 AM
11/18/08 07:54 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
If the N switch is bad the starter wont click period.In 40 years Ive never seem a bad N switch make a click.They just do nothing like the car is in gear.Sounds like a bad starter or loose terminal probally at the starter.Have someone try and start it while you listen close to the starter.If it clicks and the 2 terminals are tight smack it with a hammer lightly a few times.If it starts its the starter.That or jump the 2 wires at the starter.Rocky
Chrysler Firepower
[Re: MoparforLife]
#152617
11/18/08 05:11 PM
11/18/08 05:11 PM
Posts: 5,163 CT
GTX MATT
CT
Sounds like its got to be the starter to me. I think I might be alergic to the cold weather too. Still doesnt stop me from working on any old car. BTW I haven't learned much is different when its cold other than that gas is REALLY REALLY FRIGGIN COLD WHEN ITS COLD OUTSIDE.
[Re: DartGTDan]
#152619
11/24/08 01:52 PM
11/24/08 01:52 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
I didnt look up the part # but if its a newer Mopar mini starter, it will be a direct bolt in with the old bolts. Theres an adapter on the starter connections that needs to come off so the cables dont touch nothing.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: sooner440]
#152623
12/15/08 08:32 AM
12/15/08 08:32 AM
those bench tests arent very good. i had a starter that wouldnt turn at all. took it in to be tested and it said it tested good BUT it didnt spin once during the test. I got a new starter and it cranked like crazy!
