why would my street hemi timing marks be off by 10 deg? #1526039
10/30/13 06:39 PM
10/30/13 06:39 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
ive got a stock,fresh rebuilt 70 hemi engine that is a dog.the engine was built by someone else so i dont know the specs etc but im working on it today and using a piston stop as well as crudely confirming with a dial indicator it appears the timing marks are out by 10 degrees(advanced).
the dampner doesnt appear to have slipped and my buddy (chevy engine builder) says hes seen more than a few few cranks(chevys i assume) that have had the keyway cut wrong causing this,is this likely on a hemi crank?
if the keyway is cut incorrectly then the cam is likely installed wrong as well im thinking,possibly explaining why the motor has no power and runs poorly with black sooty spark plugs.
any thoughts from the always helpfull moparts experts?
Re: why would my street hemi timing marks be off by 10 deg? [Re: ogopogo] #1526040
10/30/13 07:19 PM
10/30/13 07:19 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
im not sure how common it is , but i have seen this problem an a street hemi with my own eyes... so it does happen
Re: why would my street hemi timing marks be off by 10 deg? [Re: ogopogo] #1526041
10/30/13 07:20 PM
10/30/13 07:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There are two different stock timing covers one is aprox ten degrees different.They were used on cast crank big blocks with the large tapered balancers.I have run into this before.Find absolute TDC with a piston stop and correct the zero mark on the tab.Also some of the bolt on tabs that have the sensor adapter are off on the degrees.We always varify the TDC mark on any timing cover during a engine build and find the many slightly off.A few degrees can make a lot of difference,especially on a hemi.
Re: why would my street hemi timing marks be off by 10 deg? [Re: B G Racing] #1526042
10/30/13 09:12 PM
10/30/13 09:12 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Sure it didnt slip ,
Re: why would my street hemi timing marks be off by 10 deg? [Re: sogtx] #1526043
10/30/13 09:23 PM
10/30/13 09:23 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've seen a Street Hemi balancer slip about the same as the one above, about 50*.
Re: why would my street hemi timing marks be off by 10 deg? [Re: B5 Bee] #1526044
10/30/13 10:57 PM
10/30/13 10:57 PM
IN
ahy Offline
ahy  Offline
IN
On my B/496 the timing marks were off 10 degrees. I believe it was caused by my repop timing cover and perhaps factory tolerences... regardless I am glad I checked like you did... first with plug hole stop then with dial indicator/head removed. Both methods gave the same position for true TDC.
Re: why would my street hemi timing marks be off by 10 deg? [Re: ogopogo] #1526045
10/31/13 12:50 AM
10/31/13 12:50 AM
Mopar, in all of it's infinite wisdom made two different balancers and timing covers for both the wedges and Street Hemi motors. The early ones, I belive 1967 or 1966 and below used a timing cover with a straight timing tab on them and balancers marked to match that cover(the zero mark is up high almost at the top of the timing tab) The later ones use a curve timing tab on the timing cover that has the zero mark about halfway down the tab and the matching balancer Why would they do that, Goverment intervention, for smog emmision reasons
Re: why would my street hemi timing marks be off by 10 deg? [Re: Cab_Burge] #1526046
10/31/13 01:55 AM
10/31/13 01:55 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Like Cab and Bob said....different timing covers/balancers for sure....and out 10* just as you say. I ran into this when I built my stroker....I sure make it a must now to double check TDC markings. Down on power, black plugs, hesitation......
Re: why would my street hemi timing marks be off by 10 deg? [Re: Cab_Burge] #1526047
10/31/13 08:04 AM
10/31/13 08:04 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The ones that I find off 10 degrees is the one with the straight tab.0- at the top of the tab.The curved tabs are real close to TDC.
Re: why would my street hemi timing marks be off by 10 deg? [Re: B G Racing] #1526048
10/31/13 11:57 AM
10/31/13 11:57 AM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Thanks guys,im sure my cover and balancer are mismatched,good to hear that others have seen this firsthand.
this engine also has the 1hemiman ebay rocker assemblies(ontario canada) on it which my motor guy insists must be replaced,so Im scrounging for rockers now too.
I can get my hands on a set of stage V's fairly quickly but they were used in a fuel car which scares me a little......
Re: why would my street hemi timing marks be off by 10 deg? [Re: ogopogo] #1526049
10/31/13 01:53 PM
10/31/13 01:53 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have seen the E-bag rockers with ratios all over the place and seen first hand the adjusters pull through the threads.
