amd shaker hood trim ring fitment #1525890
10/30/13 11:41 AM
10/30/13 11:41 AM
texas
magnum440 Offline OP
texas
hello bought shaker hood and installed trim ring and the back of the trim ring sits higher than hood..emailed persom i got hood from and he siad thats how they are...has anyone run into this and if so,,did you just leave it or modify ring and or hood....thanks in advance
Re: amd shaker hood trim ring fitment [Re: magnum440] #1525891
10/30/13 04:26 PM
10/30/13 04:26 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
The one I painted fit ok(cuda). I did hammer/dolly the hood flange, and that helped. Your hood body line looks low, maybe a skim coat of filler will help. Make sure there are no burs on the bottom side of the trim ring, or try another one.
Re: amd shaker hood trim ring fitment [Re: magnum440] #1525892
10/30/13 04:33 PM
10/30/13 04:33 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Replace the trim ring with one from BE&A, theirs will likely fit better.
Re: amd shaker hood trim ring fitment [Re: magnum440] #1525893
10/30/13 07:02 PM
10/30/13 07:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Chances are the hood is the culprit, I purchased the first initial releases of E body Shaker Hoods to avoid tooling wear/fatigue as is often seen after consecutive runs on stamped steel products where tool repair isn't performed routinely or at all, I don't have any issue with my ring/hood fit like you've posted...I'd build up/rework the hood peak/gap area
Re: amd shaker hood trim ring fitment [Re: DAYCLONA] #1525894
10/31/13 01:33 AM
10/31/13 01:33 AM
texas
texas
thanks for input ,,im thinking its the trim ring..i looked at my original shaker hood and the middle ridge isnt as raised as the front just like amd hood....lucky me guess i got a bad trim ring if no one else has had this problem..even though i was told thats how they are by person i got it from..i have an original trim ring so i tried it...it wont fit the amd hood ,,the amd trim ring is alittle wider than the original...the original trim ring isnt as raised up as amd one and its stamping is more defined.maybe its different since its for a challenger.....thanks again
Re: amd shaker hood trim ring fitment [Re: magnum440] #1525895
10/31/13 01:35 AM
10/31/13 01:35 AM
texas
texas
2
Re: amd shaker hood trim ring fitment [Re: ScottSmith_Harms] #1525896
10/31/13 05:19 AM
10/31/13 05:19 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
They do fit exceptionally well in the AMD hood, the aluminum ring supplied with the hood definitely has fitment issues. Our ring is virtually indistinguishable as being a reproduction compared to an original. The reproduction ring fits an original hood perfectly and the AMD hood the same. I've supplied many of our rings to customers because of the same issues you're having.
Re: amd shaker hood trim ring fitment [Re: HEMICUDA] #1525897
10/31/13 11:47 AM
10/31/13 11:47 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
You guys sell Challenger trim rings?!?!?
Re: amd shaker hood trim ring fitment [Re: 2fast4yourBrain] #1525898
10/31/13 03:11 PM
10/31/13 03:11 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Only Cuda.
Re: amd shaker hood trim ring fitment [Re: magnum440] #1525899
11/02/13 10:21 AM
11/02/13 10:21 AM
Wisconsin
Mopar_Mudder Offline
Wisconsin
Here are some pictures of mine, hood and trim ring came together.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: amd shaker hood trim ring fitment [Re: HEMICUDA] #1525900
11/04/13 10:06 PM
11/04/13 10:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
B/E&A's fit my 1970 factory hood perfectly too. Thanks Mike!
Re: amd shaker hood trim ring fitment [Re: ScottSmith_Harms] #1525901
11/04/13 10:16 PM
11/04/13 10:16 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
