Page 1 of 3 1 2 3
360 in 1937 truck #1525670
10/29/13 10:22 PM
10/29/13 10:22 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
What do you think! I have a chance to get a 77 360 with 727 from a camper. Less than 60k and runs very good for $600 with driveshaft.
Do i need to get anything else?
What type of perf upgrades are good? Previous owner of my project
had made some headers, so that should help
Re: 360 in 1937 truck [Re: 36dodge] #1525671
10/29/13 11:34 PM
10/29/13 11:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Camper, as in van front end camper or the big box type camper?
A 77 360 needs a performance cam for sure. A bump in compression would help a bunch too. Just do the basic 360 performance build, the camper 360 should not be anything special.
Lots of stuff may need to be upgraded on your 37 truck as you put the 360 auto in where a flat head 6 with a 3 or 4 speed used to be, or very little is everything has already been done. You may have to upgrade the brakes, the suspension, the rear axle, the wiring, built motor mounts & transmission mounts, shorten the drive shaft, change the tires and wheels, the fuel tank & gas gauge, and a few other items.
Don't give up, its all been done before, we just need to know where you're starting from. Gene
Re: 360 in 1937 truck [Re: poorboy] #1525672
10/30/13 09:46 AM
10/30/13 09:46 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if you are not looking for more performance I would just clean and regasket the motor or maybe just new timing chain, valve cover and oil pan gaskets. if it runs well, there is no need to rebuild. I would never spend that much money on a motor I was going to rebuild, I would get a $100 junkyard mystery motor for that. put a new timing chain/gears on no matter what you do. I reringed a 93k mile junkyard motorhome 360 2 years ago for a friend, it runs great in he 72 fury wagon. put a new filter in the trans and shorten the drive shaft to fit your truck.
Re: 360 in 1937 truck [Re: 65rbdodge] #1525673
10/30/13 04:02 PM
10/30/13 04:02 PM
dogdays Offline
dogdays  Offline
What are you doing for emergency brakes?
R.
Re: 360 in 1937 truck [Re: dogdays] #1525674
10/30/13 06:41 PM
10/30/13 06:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
R.
yabba dabba doo!
Don't be the exception.
Re: 360 in 1937 truck [Re: Supercuda] #1525675
10/30/13 06:58 PM
10/30/13 06:58 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Petty much any small block v8 will fit, it's just how much effort you are willing to put in. Any swap will require some fabrication and working around issues.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 360 in 1937 truck [Re: AZ_A12_BEE] #1525676
10/30/13 08:26 PM
10/30/13 08:26 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Here's more info....
The frame has been reworked by previuos owner and set up with MII front
He never finished but has done a good job....
It should be all setup for a small block LA, alum rad, 727, narrowed 8 3/4 truck rear end.
Coated headers ready to go.
Will need to consider cooling fans and some other details.
Hopefully I can use the existing oil pan off the sportsman tioga?
Plan on modifying the tioga driveshaft as well
etc
Re: 360 in 1937 truck [Re: 36dodge] #1525677
10/30/13 08:48 PM
10/30/13 08:48 PM
dogdays Offline
dogdays  Offline
My point is, the original emergency brake on the pickup was probably a band brake on a drum at the back of the transmission. Your swap engine/transmission may have the sme thing, making it easy. But it may not, as well. In that case you'll have to fabricate something up and use the emergency brakes in the 8 3/4.
R.
Re: 360 in 1937 truck [Re: dogdays] #1525678
10/30/13 10:27 PM
10/30/13 10:27 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
i'll be watching this post. i will be installing a 360 w/904 tranny into my 42 dodge truck with a 69 b-body 8 3/4 rear. was wondering what to do about the emergency brake.
Re: 360 in 1937 truck [Re: 2abodymcodes] #1525679
10/30/13 10:35 PM
10/30/13 10:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
E-brake is easy!
Just use the ones inside the drums on your 69 8 3/4, and connect the cables to the one originally from your truck, if that cable is any good.
Really, if you manage to get the motor, trans, rear axle, wiring and other brakes functioning, the e-brake should be a walk in the park. I have been know to have driven more then a few miles without a functioning emergency brake, and have lived to tell about it. We have an 04 PT that has been on the road for 10 years and 100,000 miles. I don't believe I have ever even tested the e-brake. Gene
Re: 360 in 1937 truck [Re: poorboy] #1525680
10/31/13 09:42 AM
10/31/13 09:42 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
my Desoto had the e-brake on the trans. I swapped in a 318/4speed/8.75. it was very easy to make the existing cable work with the new newer parts. If I remember correctly the stock ebrake cable has a threaded bolt on the end. I used that and made it work with parts from an 80`s ram truck from the stock cable back to the drums.
Re: 360 in 1937 truck [Re: 36dodge] #1525681
10/31/13 12:17 PM
10/31/13 12:17 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Post some pics of your truck please
Re: 360 in 1937 truck [Re: 65rbdodge] #1525682
11/07/13 03:55 AM
11/07/13 03:55 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
subscribed
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 360 in 1937 truck [Re: fstfish66] #1525683
11/10/13 04:55 AM
11/10/13 04:55 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
1st - 65rbdodge...around here u cannot find a $100 anything anymore..scrap guys
like finding a barn find and I do realize its possible
Re: 360 in 1937 truck [Re: 36dodge] #1525684
11/10/13 05:01 AM
11/10/13 05:01 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Here some pics so far....still gathering and seeking parts.
Re: 360 in 1937 truck [Re: 36dodge] #1525685
11/11/13 05:29 PM
11/11/13 05:29 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
A Mopar LA is a bolt in if you are wanting to use the stock straight axle, well assuming it is similar to my '41. Bolted right in with '70s LA truck mounts. I can take a picture if you need to see it
I had to cut a plastic piece off the old style starter to fit it where the steering box comes down. The mini wouldn't work because of it's shape
Re: 360 in 1937 truck [Re: DusterKrazy] #1525686
11/12/13 09:17 PM
11/12/13 09:17 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Since I am spending a liitle at a time....
thinking of a vlv job. Would there be a certain set of heads I should be on the lookout
for? Keep bottom end original for now. Just do top end
Re: 360 in 1937 truck [Re: 36dodge] #1525687
11/13/13 12:20 AM
11/13/13 12:20 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Most 360 heads are so identical that digging around for the best set may not be worth it. They all have 1.88/1.60 valves. The '308 casting heads from '88-91 flow great. 72/73 J heads are good to but if your heads are in good condition, just build those
Re: 360 in 1937 truck [Re: DusterKrazy] #1525688
11/13/13 10:25 PM
11/13/13 10:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've heard the Magnum 360 (5.9) heads are the best small block heads produced, but they have a different angle for the bolts that hold the intake on, so extra work/parts are required to use them on an LA motor. Gene
Re: 360 in 1937 truck [Re: 36dodge] #1525689
11/15/13 04:02 PM
11/15/13 04:02 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
the only factory heads with any gain on your motor (360) would be the 340 X heads or the 915 big valve heads, but for a streeet motor i dont think its worth the expense unless you find a set decently priced,,a pair of edelbrock heads would show better gain for the money,,or a set of magnum heads,but the magnums use the GM style rocker train and do flow better but used those are prone to be cracked,,,and IMO i perfer the shaft mounted rocker train,,the 360 makes great power stock or slightly cammed,,,
2015 cherokee
2013 R/T classic
Page 1 of 3 1 2 3
