Re: 360 in 1937 truck
[Re: 36dodge]
#1525671
10/29/13 11:34 PM
10/29/13 11:34 PM
Posts: 10,634 Freeport IL USA
poorboy
Freeport IL USA
Camper, as in van front end camper or the big box type camper? A 77 360 needs a performance cam for sure. A bump in compression would help a bunch too. Just do the basic 360 performance build, the camper 360 should not be anything special. Lots of stuff may need to be upgraded on your 37 truck as you put the 360 auto in where a flat head 6 with a 3 or 4 speed used to be, or very little is everything has already been done. You may have to upgrade the brakes, the suspension, the rear axle, the wiring, built motor mounts & transmission mounts, shorten the drive shaft, change the tires and wheels, the fuel tank & gas gauge, and a few other items. Don't give up, its all been done before, we just need to know where you're starting from. Gene
[Re: Supercuda]
#1525675
10/30/13 06:58 PM
10/30/13 06:58 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Petty much any small block v8 will fit, it's just how much effort you are willing to put in. Any swap will require some fabrication and working around issues.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: 2abodymcodes]
#1525679
10/30/13 10:35 PM
10/30/13 10:35 PM
poorboy
Freeport IL USA
i'll be watching this post. i will be installing a 360 w/904 tranny into my 42 dodge truck with a 69 b-body 8 3/4 rear. was wondering what to do about the emergency brake.
E-brake is easy! Just use the ones inside the drums on your 69 8 3/4, and connect the cables to the one originally from your truck, if that cable is any good. Really, if you manage to get the motor, trans, rear axle, wiring and other brakes functioning, the e-brake should be a walk in the park. I have been know to have driven more then a few miles without a functioning emergency brake, and have lived to tell about it. We have an 04 PT that has been on the road for 10 years and 100,000 miles. I don't believe I have ever even tested the e-brake. Gene
[Re: 36dodge]
#1525687
11/13/13 12:20 AM
11/13/13 12:20 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Since I am spending a liitle at a time.... thinking of a vlv job. Would there be a certain set of heads I should be on the lookout for? Keep bottom end original for now. Just do top end
Most 360 heads are so identical that digging around for the best set may not be worth it. They all have 1.88/1.60 valves. The '308 casting heads from '88-91 flow great. 72/73 J heads are good to but if your heads are in good condition, just build those
[Re: 36dodge]
#1525689
11/15/13 04:02 PM
11/15/13 04:02 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
the only factory heads with any gain on your motor (360) would be the 340 X heads or the 915 big valve heads, but for a streeet motor i dont think its worth the expense unless you find a set decently priced,,a pair of edelbrock heads would show better gain for the money,,or a set of magnum heads,but the magnums use the GM style rocker train and do flow better but used those are prone to be cracked,,,and IMO i perfer the shaft mounted rocker train,,the 360 makes great power stock or slightly cammed,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
