Trunk seam finish ?? #1525584
10/29/13 07:00 PM
10/29/13 07:00 PM
68gtx Offline OP
68gtx  Offline OP
Can someone tell how this seam should be finished?? Seam sealer ,filler or combination of. This is a pic of the seam left and right side of trunk where the quarter meets the trunk and lower rear window panel. Thanks Larry J
Re: Trunk seam finish ?? *DELETED* [Re: 68gtx] #1525585
10/29/13 07:04 PM
10/29/13 07:04 PM
68gtx Offline OP
68gtx  Offline OP
Post deleted by 68gtx
Re: Trunk seam finish ?? [Re: 68gtx] #1525586
10/29/13 07:07 PM
10/29/13 07:07 PM
68gtx Offline OP
68gtx  Offline OP
What the $#@$^&&.
Re: Trunk seam finish ?? [Re: 68gtx] #1525587
10/30/13 10:21 AM
10/30/13 10:21 AM
68gtx Offline OP
68gtx  Offline OP
Tried to resize thats the only pic I have. Anyone have pics of how they treated this area. Thanks larry j
Re: Trunk seam finish ?? [Re: 68gtx] #1525588
10/30/13 03:23 PM
10/30/13 03:23 PM
North East
MaxHeadroom Offline
MaxHeadroom  Offline
North East
If you mean the joint of the main trunk section and outer extensions, then seam sealer only. Not sure what that is the photo of.
Re: Trunk seam finish ?? [Re: MaxHeadroom] #1525589
10/30/13 05:57 PM
10/30/13 05:57 PM
68gtx Offline OP
68gtx  Offline OP
I know I tried to resize it. I will try again. If you open the trunk there is a seam both left and right upper portion in the area of the hinges. If that makes since. Thanks larry J
Re: Trunk seam finish ?? [Re: 68gtx] #1525590
10/30/13 06:06 PM
10/30/13 06:06 PM
68gtx Offline OP
68gtx  Offline OP
Another pic I hope.
Re: Trunk seam finish ?? [Re: 68gtx] #1525591
11/05/13 06:48 PM
11/05/13 06:48 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Looks like the area where the top of the quarter meets the gutter /dutchman panel...Most likely you are dealing with seam sealer. Mine had a lot slopped on from the factory in the area. Shouldn't be using ant filler there.
Re: Trunk seam finish ?? [Re: cudabitten] #1525592
11/05/13 08:56 PM
11/05/13 08:56 PM
68gtx Offline OP
68gtx  Offline OP
Anyone have pics of how this area should be finished correctly??? Thanks Larry J
