The original vendor did make some for the aftermarket, back in the day, that are identical with the exception of not being stamped with the Pentastar & Chrysler part numbers.
Even the hose is of the correct style with the right markings and raised ribs.
This is one that I had for a while & sold earlier this year.
Otherwise, your options are NOS or to re-plate a good original. If you do need a good original hose for re-plating (with the correct markings), then PM me.
Unfortunately, the current crop of hoses all have horribly incorrect crimps and many now have aluminum ends too....
