98 Ram SS/T : Transmission filter and ATF change #1525052
10/29/13 12:21 AM
10/29/13 12:21 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I bought my 98 Ram SS/T in 2005 with 85K on it. Transmission fluid was a little Brown but not bad. There was no junk in the pan.
I replace filter and five or six quarts of ATF +3 as specified in owner's manual. I also installed a drain plug in the pan.
Here is the question: Now at 121K transmission fluid still looks nice and Red. Should I replace filter and fluid? Just fluid? Leave it alone? What interval do you guys recommend? I don't tow and no heavy use.
Re: 98 Ram SS/T : Transmission filter and ATF change [Re: Gabmando] #1525053
10/29/13 09:06 PM
10/29/13 09:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I always recommend every 30-35k miles but do filter and fluid.
think about it would you change your engine oil without replacing the filter.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 98 Ram SS/T : Transmission filter and ATF change [Re: dusturbd340W5] #1525054
10/29/13 10:44 PM
10/29/13 10:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
What interval does the owners manual recomend?
I am truckless..
Re: 98 Ram SS/T : Transmission filter and ATF change [Re: 340SHORTY] #1525055
10/29/13 11:50 PM
10/29/13 11:50 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I would replace the fluid. The filter is up to you.
It's Swifty! Swifty, you toad sucker!
