Re: Cam Change - Issues???
[Re: CUDAJAS]
#1525035
10/29/13 02:11 AM
10/29/13 02:11 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Mopar Action magazine did a great article on how to start a fresh engine. It shows how to absolutely ensure that the engine starts on the very first few revolutions. The failure of these types of cams is directly related to extended cranking on a fresh start AND the proper oil used. This is assuming that you are using the proper valve springs according to the Cam manufacturer. Get the engine to start immediately AND use the right oil. Your chances of success are good.
[Re: Twostick]
#1525038
10/29/13 10:10 PM
10/29/13 10:10 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Use a good 15/40 diesel oil like Rotella or Mobil Delvac. If you can't sleep at night, add a can of GM EOS or equivalent.
Make sure ALL, repeat ALL the lifters are spinning BEFORE you fire it up. IMHO 90+% of cam failures are caused by a lifter that wasn't turning.
When you turn the engine over on the starter, all the push rods should spin quickly and evenly. A slow one or a stopped one is trouble. Swap the lifter to a different hole and try again. If it won't spin in that hole,replace the lifter. If the one in the original hole still won't spin, check the lifter bore.
This check can be done in a very few seconds and IMO is critical.
Kevin
I agree & great advice. I just switched cams in my 383, using plenty of cam lube, a bottle of Trick Flow breakin oil & no issues with the new cam & its been 4 months now. I try to add a quart of Comp break in oil with oil changes just to be sure I have enough zinc & phosporous, etc.
[Re: Triggerfish]
#1525039
10/29/13 10:22 PM
10/29/13 10:22 PM
RapidRobert
I'd suggest mocking up each lifter in a bore cleaned with brake kleen & lightly lubed with WD40 & lift each lifter up off of its' lobe with your finger & let go of it & it should fall back onto its' respective lobe with a resounding "thunk"
[Re: Kern Dog]
#1525040
10/30/13 01:15 AM
10/30/13 01:15 AM
Posts: 205 Martinsville, VA
440child
Martinsville, VA
Would anyone have a copy of this by any chance?
[Re: 80fbody]
#1525041
11/01/13 04:19 PM
11/01/13 04:19 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Thanks for the input guys. I would likely go with the lunati voodoo cam and lifter package. Quote:
I would source some Johnson lifters. Much better luck with those. Check with guys like Comp. Wedge, Compuflow, ect. Seem to be much more helpful getting those, if available.
These are the comments that scare me.
Is there an issue with Lunati lifters or the other cam and lifter kits?
Jason
