Thanks 68 Sat that'd be great! My main question is how far forward does it extend? Does it go up the axle hump, or does it stop at the base of the hump? On the sides I imagine it stops at or near the edge of the drop off. At the tail panel, how far past the vertical brackets does it go? If it happens to already be out of the car, measurements would be helpful. Otherwise I can lay my mat in the trunk, mark and trim it. Thanks for your help!
The original mat for the car was pretty torn up, but I saved pieces of the hounds tooth pattern.
