Hemi T & D Barton Rocker Oiling #1524734
10/28/13 01:56 PM
10/28/13 01:56 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
When using these Barton Hemi Rockers and running pushrod oiling
Do you need any extra oiling to the rockers or is that enough?
Also would you bush the lifter bores on a aluminum block?
Re: Hemi T & D Barton Rocker Oiling [Re: Sammy] #1524735
10/28/13 03:46 PM
10/28/13 03:46 PM
Call Barton and ask them about both
Re: Hemi T & D Barton Rocker Oiling [Re: Cab_Burge] #1524736
10/28/13 05:07 PM
10/28/13 05:07 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'd rather not have to deal with them at any level
They had my motor on an engine stand for 7 months
While they had $17,000 of my money
Re: Hemi T & D Barton Rocker Oiling [Re: Sammy] #1524737
10/29/13 07:55 AM
10/29/13 07:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Which Barton setup are you using?The ones with the stand plate that bolts to the head has a spray bar the oils the rockers.
Re: Hemi T & D Barton Rocker Oiling [Re: B G Racing] #1524738
10/29/13 09:24 AM
10/29/13 09:24 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Push rod oiling is enough, provided the rockers you have are drilled for through oiling and have oiling adjusters in them. Test them ALL with an air hose when you know about where the adjuster will wind up with proper lash. The groove in the adjuster oils best at about two turns in from full out. Occasionally TD forgets to cut the groove behind the bearings that allow oil to pass though the body to the tip. That's why you should test them all.
If you have wide main, and rod clearance with a main priority oiling block the front lifter pairs left, and right will benefit from a very small slot cut in the tappets connecting the oil hole to the oil band. At idle, with a vacuum pump, they'll be no oil up there on those cylinders without it.
Re: Hemi T & D Barton Rocker Oiling [Re: Sammy] #1524739
10/29/13 11:41 AM
10/29/13 11:41 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
What was the hold up? Waiting for parts?
Re: Hemi T & D Barton Rocker Oiling [Re: DodgeCharger] #1524740
10/30/13 07:53 AM
10/30/13 07:53 AM
pa
572charger Offline
572charger  Offline
pa
i never used any pushrod oiling just the spray bars on the T-D set up ive got the oil lines from the lifter oil galleys going to them and it still gets oil from the camshaft groove also mine is a street car so i like more oil to the valve train never had any issues the push rods and all the rocker gear looks like the day i installed it in 2003 !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi T & D Barton Rocker Oiling [Re: 572charger] #1524741
10/30/13 12:13 PM
10/30/13 12:13 PM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
I've got Barton's t&d rockers on my 572 Hemi bushed bores and tapped 1/8" NPt off the lifter galleys. Cast iron mega block. No problems with oiling.
Re: Hemi T & D Barton Rocker Oiling [Re: 572charger] #1524742
10/30/13 12:22 PM
10/30/13 12:22 PM
Mohnton, Pa
Mohnton, Pa
I'm also only running spray bars. I also drive my car on the street.
Mega block bushed lifter bores.
