98 jeep transmission problems #1524559
10/28/13 12:51 AM
10/28/13 12:51 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
98 grand cherokee,4.0 6 cyl,42re trans,as the weather gets colder it dont want to shift from 1st to second without flaring the engine speed a little,2nd to 3rd is really bad,once it warms up its fine,it has about 160,000 on it,fluid and filter changed 1 yr ago at 150,000,no problems in warm weather,are the seals old and dried up,or is something else going on?
thanks in advance
Re: 98 jeep transmission problems [Re: rhad] #1524560
10/28/13 01:07 AM
10/28/13 01:07 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Have the bands ever been adjusted?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 98 jeep transmission problems [Re: hp383] #1524561
10/28/13 12:01 PM
10/28/13 12:01 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
the bands were adjusted when the fluid was changed
Re: 98 jeep transmission problems [Re: rhad] #1524562
10/29/13 07:48 AM
10/29/13 07:48 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
solenoids ?
Re: 98 jeep transmission problems [Re: d-150] #1524563
10/29/13 09:04 PM
10/29/13 09:04 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
we in the business call it morning sickness, what happens is as the rubber seals get old they begin to get hard and do not seal very well allowing oil pressure to leak by especially in cold weather
now as you get some heat in them they start to soften a little and they begin to hold pressure again so it begins working better until you allow it to sit and cool back down.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 98 jeep transmission problems [Re: dusturbd340W5] #1524564
10/30/13 02:19 PM
10/30/13 02:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are no rubber seals involved in the 1-2 upshift.
Re: 98 jeep transmission problems [Re: John_Kunkel] #1524565
10/30/13 07:51 PM
10/30/13 07:51 PM
Kissimmee Fl.
Kissimmee Fl.
that's correct but there damnn sure is on the 2-3 they also had a large problem with undersized inner seals on the front drum, which does come into play on the 2-3.
Re: 98 jeep transmission problems [Re: dusturbd340W5] #1524566
10/30/13 07:52 PM
10/30/13 07:52 PM
Kissimmee Fl.
Kissimmee Fl.
and if you read the OP post 2-3 is what is really bad.
Re: 98 jeep transmission problems [Re: dusturbd340W5] #1524567
10/31/13 02:07 PM
10/31/13 02:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The point is, a lazy 1-2 shift with recently adjusted bands means there is no easy fix ala "Miracle-in-a-Bottle".
Re: 98 jeep transmission problems [Re: John_Kunkel] #1524568
10/31/13 08:10 PM
10/31/13 08:10 PM
Kissimmee Fl.
Kissimmee Fl.
that was my point it needs to come out and be gone into
