New SB heads
#1524184
10/27/13 01:34 PM
10/27/13 01:34 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Now, everyone knows I'm a hemi guy, but this is interesting. Everyone knows that the old Poly 318 was a semi hemi, similar to a big block Chevy. BREAKING NEWS-SMALL BLOCK HEADS BREAKTHROUGH may make all wedge heads obsolete! Left is a Poly "A" block with 360hp heads and Edelbrock Performer... Right is the 360hp block they came off of with Poly heads installed and Hot Heads manifold we're using as the pattern for our new Poly SS-X and SS-2X manifolds... Poly heads properly prepared will really "wake up" any small block no matter whose heads you already have! The Poly combustion chamber and Hemi-like valve layout are far superior to any wedge design! Aluminum poly heads for small blocks are in the works...Hot Heads, who does a lot of early Hemi stuff, is involved in this deal....
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
Re: New SB heads
[Re: topside]
#1524189
10/27/13 06:37 PM
10/27/13 06:37 PM
Quicktree
Re: New SB heads
[Re: max]
#1524195
10/28/13 04:27 PM
10/28/13 04:27 PM
Steve1118
Not really sure of all the details, but I do know that this project is going ahead full steam. I know that Hot Heads has their fingers in it, and there will be both single four barrel intakes and a 2 four crossram once things are up and running. As I hear, the heads will have a much larger port size than the original poly heads, and will bolt on any standard "LA" block.
I'm really surprised no one has done this before, that poly head with it's canted valve always had a lot of potential.
I'll keep everyone posted when I hear anything.
Re: New SB heads
[Re: WHITEDART]
#1524199
10/28/13 05:45 PM
10/28/13 05:45 PM
Posts: 4,255 Canada
WO23Coronet
Canada
That would be funny if the standard block is already set up for them with the 59 degree block, might give the 48 degree guys a bit of angle envy Just for fun, any bets whether they would have the stock single shaft set up of go to a pedestal/stud mount ala BBC or Cleveland Ford?
Re: New SB heads
[Re: Streetwize]
#1524201
10/28/13 08:49 PM
10/28/13 08:49 PM
dogdays
Go to www.vintagev8s.com to see good pictures of their DeSoto Hemi intakes that Hot Heads sells. I've been bugging them and Hot Heads for a couple of years now to get a Poly intake into production, the $500 Weiand 7503s are just too expensive for what you get, and I've got one in my back yard. A modern dual plane intake should be much better than the Weiand. The primary reason that Mopar made the LA out of the A was to shave about 50lb off the weight. Making it narrower was probably secondary. I believe the 59 degree valve angle was carried over to save $ and I also believe the A motor was a copy of the original Firepower with slightly shorter bore spacing, 4.46" instead of 4.5625", roughly 1/10 of an inch shorter. But there's a reason the timing set from 354/318Poly/318LA is the same. R.
Re: New SB heads
[Re: HotRodDave]
#1524203
10/28/13 09:58 PM
10/28/13 09:58 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
This will be a great choice for the guys who bought 59 degree R3 blocks.
I will just stick with the P7 for now. But, love to hear that people are actually trying new things that can improve HP for the Mopar crowd.
Leon
