Reverse wire harness trans clips question #1523911
10/27/13 12:19 AM
10/27/13 12:19 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Where on the 833 Trans were the clips put originally?
Pictures appreciated.
http://www.ebay.com/itm/380724212373?ssP...49#ht_335wt_679
Re: Reverse wire harness trans clips question [Re: Topcat] #1523912
10/27/13 04:47 AM
10/27/13 04:47 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
This is a terrible lo-res diagram from a service manual (not my photo). I couldn't find it in my digital copy, so hope this helps.
Re: Reverse wire harness trans clips question [Re: filmsurgeon] #1523913
10/27/13 11:53 AM
10/27/13 11:53 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
That helps thanks.
It looks like there's another type of harness clip on the bellhousing as well. I'd like to see what they look like as well.
Re: Reverse wire harness trans clips question [Re: filmsurgeon] #1523914
10/27/13 12:10 PM
10/27/13 12:10 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Somebody a while back had that same picture, and one for a Hemi, and it had one or two extra clips, that is if you were doing a Hemi.
Re: Reverse wire harness trans clips question [Re: 71birdJ68] #1523915
10/27/13 01:21 PM
10/27/13 01:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the clip that goes on the bell housing, it goes under the bolt that is in the 1:00 position (first bolt right from center if you are facing the rear of the engine). It was installed before paint so got paint over spray on it.
Clip
Re: Reverse wire harness trans clips question [Re: Topcat] #1523916
10/27/13 01:42 PM
10/27/13 01:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike, I assume you want the 1971 HEMI E body application?...if so, this print covers both Auto/4spd
Mike
Re: Reverse wire harness trans clips question [Re: DAYCLONA] #1523917
10/27/13 09:51 PM
10/27/13 09:51 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Thanks for the help guys.
