Page 3 of 3 1 2 3
Re: T&T results with 13 lbs boost [Re: FastmOp] #1523689
11/22/13 11:16 AM
11/22/13 11:16 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Thanks guys! I wish I had an aftermarket block...
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523690
11/22/13 11:29 AM
11/22/13 11:29 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I've been hitting mine with 18.8 psi of boost and spinning it to 7,000 for quite some time on the stock block with factory caps and bolts and no fill. I'm betting you still have LOTS of room left to work with. I think the "myth" about how much these blocks can take is based on failed parts with bad tunes.
Re: T&T results with 13 lbs boost [Re: Duner] #1523691
11/22/13 11:51 AM
11/22/13 11:51 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I agree. Look at a Windsor ford. Very weak looking compared to a 318-360 Mopar platform. Lots of after market blocks for the ford now but in the 80's and 90's lots of very fast stock blocks. As long as you keep a handle on the tune I think a turbo is easier on engine blocks and parts.
Getting old just means you were smarter than some and luckier than others.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523692
11/22/13 01:29 PM
11/22/13 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`ve really got that thing scootin for sure...............
Re: T&T results with 13 lbs boost [Re: Thumperdart] #1523693
11/23/13 11:20 AM
11/23/13 11:20 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
We'll see how good the stock block is in turbo form. I have some upgrades coming this winter that are really going to put it to the test in the spring.
Re: T&T results with 13 lbs boost [Re: dizuster] #1523694
11/23/13 08:59 PM
11/23/13 08:59 PM
Houston, Texas
Houston, Texas
From a lot of things I have read, a turbo is not as hard on a motor as N/A or other forms of power adders.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1918527
09/24/15 12:47 AM
09/24/15 12:47 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
What Fast box are you running? And what RPM is it pulling thru the traps?
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1918541
09/24/15 01:05 AM
09/24/15 01:05 AM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
James that's awesome!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1918629
09/24/15 09:14 AM
09/24/15 09:14 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Lol... This thread is from 2013
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1919650
09/25/15 06:48 PM
09/25/15 06:48 PM
Houston, Texas
Houston, Texas
haha, ya, but I haven't run the truck at the track since! I do plan on going in a few weeks to try out my fancy boost controller.
Josh: Thanks! Hope all is well for you there! I see your dad made the magazines!
Randy: I am running Classic FAST and pull 6,000-6100 through the traps.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1920330
09/26/15 11:40 PM
09/26/15 11:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best as you have it running real good. beer I always wonder just how much the boost makes it pick up ? I mean if you took the turbo off what do you think it would run ? I am just curious of about how much the turbo helps as it seems many of the fast turbo cars I see have engines that are not all that heavily built and are closer to stock then I thought. It does surprise me how well some of them hold up under boost. But you sure have it running good. up Ron
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1920502
09/27/15 11:29 AM
09/27/15 11:29 AM
Houston, Texas
Houston, Texas
I would guess the motor makes around 350 hp. 389 cubes, M1, home ported Eddy heads (2.02/1.62), .520 hydraulic roller cam (wide LSA with 220 duation), 9.4:1 compression.
With the tight converter and no gearing with tall tires (3.55, 30" tall) I would guess somewhere around low 12's.
Page 3 of 3 1 2 3
