Smoking 440, what is a good oil additive? #1523362
10/25/13 10:13 PM
10/25/13 10:13 PM
San Jose,CA
migsBIG Online happy OP
YouTube is my go-to news source
migsBIG  Online Happy OP
San Jose,CA
The 440 motor in my 70' barracuda seems to be smoking a bit and was looking to do a temporary fix before I pull it this winter. Could be rings or valve seals, leak down test didn't revel which one. Just want to dive it a couple more times before the teardown. Any suggestions?
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523363
10/25/13 10:28 PM
10/25/13 10:28 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
lucas oil stabilizer.. if it is the ring set , we always used Engine Restorer with the copper flakes to fill in scratches from the sand that always found its way in the engines. it was a temp. fix when they were due a rebuild only.. if the seals are gone, pretty much nothing will help it.
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523364
10/25/13 10:30 PM
10/25/13 10:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ahh screw it. Let it smoke. It's an old car. Nothing you dump in the crank case is going to stop the smoke.
Coming soon!!!!
Re: Smoking 440, what is a good oil additive? [Re: ek3] #1523365
10/25/13 10:40 PM
10/25/13 10:40 PM
San Jose,CA
San Jose,CA
Ok, it never runs hot unless parked for like 20 minutes running. Never used Lucas one, and the local shops all carry a Engine Restorer, so that might work, thanks.
Re: Smoking 440, what is a good oil additive? [Re: Mr.Yuck] #1523366
10/25/13 10:46 PM
10/25/13 10:46 PM
E
ek3 Offline
ek3  Offline
E
hey,MR. yuck , GREAT point ... if it will smoke the tires like the one in your picture, who will know anyhow? !!
Re: Smoking 440, what is a good oil additive? [Re: ek3] #1523367
10/25/13 11:05 PM
10/25/13 11:05 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Toss a 40 of Schlitz in the crankcase.
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523368
10/25/13 11:09 PM
10/25/13 11:09 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
if still available....marvel mystery oil
Re: Smoking 440, what is a good oil additive? [Re: terzmo] #1523369
10/26/13 12:52 AM
10/26/13 12:52 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Clean the mouse ball.
Oh, wrong forum.
Save the 20 bucks and let it blow.
Make smoking cool again.
I can't afford this. mark
Re: Smoking 440, what is a good oil additive? [Re: a12superbee] #1523370
10/26/13 08:59 AM
10/26/13 08:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Restore does help.I had an old 318 in one plow truck.It had 300K.Smoked and I used Restore.It did cut it down quite a lot and even seemed to run better.Wont fix a major problem.Lucas might help but restore will probally do better.Rocky
Chrysler Firepower
Re: Smoking 440, what is a good oil additive? [Re: therocks] #1523371
10/26/13 09:44 AM
10/26/13 09:44 AM
San Jose,CA
San Jose,CA
Ok, gonna try the Restore treatment and see how it works. Since I have video on the phone and camera, ill see how much smoking it will go down. Thanks for the info, will update Sunday and see if there was any difference.
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523372
10/26/13 10:00 AM
10/26/13 10:00 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
on oil burnners i usually use an overfill of about 1 quart for an oil treatment,that way you dont have to keep checking the level as often.
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523373
10/26/13 09:49 PM
10/26/13 09:49 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Check your city ordinances first.
dstryr, since 1986.
Re: Smoking 440, what is a good oil additive? [Re: migsBIG] #1523374
10/26/13 11:13 PM
10/26/13 11:13 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Gonna give my endorsment to the RESTORE. Used a can in my old $280 68 Newport(back in my drinkin days). After adding it you could no longer smell the blow by when beating the snot out of the engine.It would cross plowed frozen fields, and jump train tracks without a hint of blowby. Sold that poor engine to a guy who was going to put it in an I.H.Scout.He never came back,so I guess it must have met his performance expectations.
Re: Smoking 440, what is a good oil additive? [Re: 67_Satellite] #1523375
10/28/13 07:45 AM
10/28/13 07:45 AM
San Jose,CA
San Jose,CA
Put the Restore in the car and O'Rieleys 30w with Wix filter and let it run for a little bid. Smoking went down to 1/2 of what is was just on warming up the engine! Within a 15 minute drive, I could come up to a stoping and see that i was not smoking out other drivers anymore (before, you could see fumes of smoke flying by like a fog bank!). Will give it another test drive in the week when I pop on a fresh distributor, rebuilt hi output altornator and rebuild the oil pump. Heck, I feel good that my ride isn't too hooptie for me to enjoy it a bit more. thanks for the idea on the Restore additive, might save me from rebuilding my engine sooner than it needs to be.
