Re: Who is good with Dana 60??
[Re: Randy..]
#1523339
10/25/13 11:00 PM
10/25/13 11:00 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
ain,t no 80, they had bigger load tubes and A LOT more beef around the whole unit, key if it looks just a pass car except for the pinion snubber mnt pad most likely a 60.
He said Ford Truck. I find it harsh to believe that you can't find any 72-93 Dodge 3/4-1tons. A Very Large chunk of them are D60s. No clue what fords had
[Re: 76dodgeboy]
#1523345
10/27/13 01:28 AM
10/27/13 01:28 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
On the back side of the Passenger side axle tube you will find a string of 6 numbers stamped into the tube. The first number will be 6 for a 60. Take the numbers to a differential shop that has all the Dana Spicer catalogs and look up the number. When a new version of the catalogs are printed, they drop the older listings so you will probably have to look at more than one catalog. If the tube has been changed then... You mentioned the 16 spline axles, IIRC that is a common Ford deal. A new Limited Slip Differential with 30 to 35 spline axles is in your future if you put any real power to the ground. I have a rebuilt 30 spline PowerLock carrier that will accept 3.54 to 4.10 gears if you need it. PM me if you are interested, I want to move it. Good Luck
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1523347
10/28/13 01:40 PM
10/28/13 01:40 PM
Posts: 993 Mid Michigan
Mr. Smurf
Mid Michigan
This.
The numbers are all you need. The Dana/Spicer catalogs DO NOT list axles by vehicle, they can't help you without the number.
Ed
