Who is good with Dana 60?? #1523337
10/25/13 09:33 PM
10/25/13 09:33 PM
Carroll, IA
jercars Offline OP
jercars  Offline OP
Carroll, IA
I'm building a 68 charger and I want a dana 60 in it but they're tough to find and super expensive. I'm more than capable of building one and I found what I hope is a good piece at the local junk yard. It's out of a 74 F-250, has 3" tubes instead of 3.125" which is perfect for me because that's what it would've been in a real dana car. It has the 9.75 ring gear and the tag bolted on the back indicates that it's a 60. The problem is down on the lower right web it has 80 casted on it where it should say 60. I scraped it good and i'm not mistaken it really says 80. Is this a factory mistake or is it some weird odd ball cross breed rear end. It's still a full floater with 8 bolt hubs, also is 4.10 with those coarse 16 spline axles if that helps paint a better picture for you. I know off road guys like danas so that's why I'm asking here.
Re: Who is good with Dana 60?? [Re: jercars] #1523338
10/25/13 09:38 PM
10/25/13 09:38 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
ain,t no 80, they had bigger load tubes and A LOT more beef around the whole unit, key if it looks just a pass car except for the pinion snubber mnt pad most likely a 60.
Re: Who is good with Dana 60?? [Re: Randy..] #1523339
10/25/13 11:00 PM
10/25/13 11:00 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He said Ford Truck. I find it harsh to believe that you can't find any 72-93 Dodge 3/4-1tons. A Very Large chunk of them are D60s. No clue what fords had
Re: Who is good with Dana 60?? [Re: 76dodgeboy] #1523340
10/26/13 12:04 AM
10/26/13 12:04 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I've got three of them laying around that nobody seems to want. I have a 77 D200 crew cab frame, a 77 D200 club cab, and a 92 D200 that had a Cummins. I assume they are all D60's
JB Rhinehart, Realist
A-Body's RULE!
Re: Who is good with Dana 60?? [Re: 76dodgeboy] #1523341
10/26/13 01:18 AM
10/26/13 01:18 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I think he wants to use that Ford 60 because it has a 3" axle tube if I understand his comment correctly
Re: Who is good with Dana 60?? [Re: hp383] #1523342
10/26/13 12:19 PM
10/26/13 12:19 PM
Carroll, IA
jercars Offline OP
jercars  Offline OP
Carroll, IA
Thank you hp383. You are exactly right, I want the 3" tubes for authenticity. I know it's a 60 i'm just trying to figure out why it has 80 on the casting instead of 60. I dont know if its just a factory flaw or if there is something else going on here. That"s all.
Re: Who is good with Dana 60?? [Re: jercars] #1523343
10/26/13 12:52 PM
10/26/13 12:52 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have to agree with Randy because when you see a 60 next to an 80 there is a dramatic difference between the two. Every early f250 I have seen is a 60 and even 350's had 60's in them. I think that 80 you see is possibly a casting mistake because the 3" tubes are the tip off that it's a 60
Gus
64 Plymouth Savoy
Dana 60
Re: Who is good with Dana 60?? [Re: fourgearsavoy] #1523344
10/26/13 06:59 PM
10/26/13 06:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Call Ford.
Not authentic when a ford D60 and and a truck one at that. build date and serial number will be different too
Re: Who is good with Dana 60?? [Re: 76dodgeboy] #1523345
10/27/13 01:28 AM
10/27/13 01:28 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
On the back side of the Passenger side axle tube you will find a string of 6 numbers stamped into the tube. The first number will be 6 for a 60. Take the numbers to a differential shop that has all the Dana Spicer catalogs and look up the number. When a new version of the catalogs are printed, they drop the older listings so you will probably have to look at more than one catalog. If the tube has been changed then...
You mentioned the 16 spline axles, IIRC that is a common Ford deal. A new Limited Slip Differential with 30 to 35 spline axles is in your future if you put any real power to the ground. I have a rebuilt 30 spline PowerLock carrier that will accept 3.54 to 4.10 gears if you need it. PM me if you are interested, I want to move it.
Good Luck
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Who is good with Dana 60?? [Re: 76dodgeboy] #1523346
10/28/13 01:05 PM
10/28/13 01:05 PM
Carroll, IA
jercars Offline OP
jercars  Offline OP
Carroll, IA
76dodgeboy.... I'm well away the numbers won't match on the rear end. The numbers on the 426 Hemi I have sitting here to go in the car don't match either but I haven't heard any complaints about that yet. I'm concerned with the correct appearance and that's why I inquired about this axle since it has the correct size tubes. Also since this is a non numbers matching car I don't care if a Dana came out of a Ford, a Mopar, or the even space shuttle for that matter; they were all still built by Dana Corporation, not the auto manufacturer. Numbers don't mean squat to me on this particular car so long as it's the correct dimensions and appearance. As for you other guys out there that have helpful and positive things to say; thank you all very much for your help and support.
Re: Who is good with Dana 60?? [Re: Polarapete] #1523347
10/28/13 01:40 PM
10/28/13 01:40 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
This.
The numbers are all you need. The Dana/Spicer catalogs DO NOT list axles by vehicle, they can't help you without the number.
Ed
Re: Who is good with Dana 60?? [Re: Mr. Smurf] #1523348
10/28/13 03:01 PM
10/28/13 03:01 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
You will need to get the BOM build of material number off of the passenger side axle tube. That will tell you what you have.
Matt
Re: Who is good with Dana 60?? [Re: mattsmopars] #1523349
10/28/13 11:06 PM
10/28/13 11:06 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Its a Dana 60.. Early ones had 16 Spline axles , They also used a 1 1/4 Pinion Nut and the Later ones used a 1 5/16 Pinion Nut..The early Dana 60 used a 10 spline Pinion and later used a 29 spline
The Dana 80 uses a 1 7/8 Pinion Nut and Has 37 Spline Pinion.. There is a size difference in the pinions.... D 60 is just over 1 1/4 and the D80 is 1 5/8
www.Greensburgmachine.com
Re: Who is good with Dana 60?? [Re: Mpetros] #1523350
10/28/13 11:12 PM
10/28/13 11:12 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
If it has a Dana Ring Gear in it , You can tell by the number that's in the Ring Gear too.
