Who's making MP camshafts these days? #1523267
10/25/13 05:25 PM
10/25/13 05:25 PM
Birmingham, England
Mick70RR Offline OP
Mick70RR  Offline OP
Birmingham, England
Fitted a new MP camshaft a few weeks ago and there was no purple paint on it. It also had the part number etched on it, something I've never seen before.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Who's making MP camshafts these days? [Re: Mick70RR] #1523268
10/25/13 05:25 PM
10/25/13 05:25 PM
Birmingham, England
Mick70RR Offline OP
Mick70RR  Offline OP
Birmingham, England
Another pic.
Re: Who's making MP camshafts these days? [Re: Mick70RR] #1523269
10/28/13 01:38 PM
10/28/13 01:38 PM
dogdays Offline
dogdays  Offline
The number in the second picture was cast into the core, has nothing to do with who ground the cam. Camshaft cores are produced in large quantities by only a couple of companies. They are cast and hardened and delivered to the grinder as blanks.
Several years ago, Crane Cams bought about all the cam grinding capacity in the US, so unless the cam grinder has its own facilities the cam was probably ground in a Crane plant. I don't know what happened in the bankruptcy a few years ago, it's possible that part of the company got sold.
Chase Knight, got your ears on?
R.
Re: Who's making MP camshafts these days? [Re: Mick70RR] #1523270
10/28/13 04:40 PM
10/28/13 04:40 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Almost all hydraulic and flat tappet cams that are cast cores ( such as yours) are made by the same company ( or two). The cam you have is the same as you might see from a shelf Comp Cams or any of the cast camshafts. The cam core company supplies cores, then others may grind, tap, do the bolt holes etc. CWC is just the casting. Most of the Comp Cam hydraulic and flat tappet shelf type grinds, arent done in house. The other mentioned companies actually do all the work. In the case of a full on custom, then Comp ( and the others ) MAY grind their own.
RIP Monte Smith
Re: Who's making MP camshafts these days? [Re: Mick70RR] #1523271
10/28/13 05:07 PM
10/28/13 05:07 PM
AndyF Offline
AndyF  Offline
That is cool that they finally got around to putting the part number on them. For years there was no good way to know which cam was what.
Re: Who's making MP camshafts these days? [Re: CompWedgeEngines] #1523272
10/28/13 05:12 PM
10/28/13 05:12 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The 111024 looks like a Camshaft Machine Company part number. They are in Jackson, MI. They were a division of Crane Cams in the 1980-1990 area, but are now self-owned. In addition to finish grinding, they also produce the semi-finished cam cores from CWC castings that many of the cam grinders use. Regards, Chase
Re: Who's making MP camshafts these days? [Re: cknight] #1523273
10/28/13 06:28 PM
10/28/13 06:28 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Lowest bidder is making the cams...
Tony
70 AARCuda Vitamin C
Re: Who's making MP camshafts these days? [Re: cknight] #1523274
10/28/13 08:23 PM
10/28/13 08:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Chase is correct,it is Camshaft Machine Co.,and they have been grinding the MP cams since the 80's,and probably before then.
Nautilus Racing-
Re: Who's making MP camshafts these days? [Re: Chris2581] #1523275
10/28/13 09:10 PM
10/28/13 09:10 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I THINK the CWC stands for the Campbell Wyant and Cannon foundry. They cast a ton of parts for everybody over the years. Still in business as a part of Textron.
Re: Who's making MP camshafts these days? [Re: 6PakBee] #1523276
10/29/13 01:10 AM
10/29/13 01:10 AM
Syracuse,NY
Syracuse,NY
That is correct. At one time they were claimed to do almost 75% or more of all the cams. ( these types anyhow)
RIP Monte Smith
Re: Who's making MP camshafts these days? [Re: cknight] #1523277
10/29/13 09:19 AM
10/29/13 09:19 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Chase Hello, Martin Wimberly here, Auto Aftermarket Sales / Product Manager with Radiac Abrasive, I work with Dave Fisher.
MLR426
