3" exhaust e bodys ? #1523096
10/25/13 01:37 AM
10/25/13 01:37 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
who on here has used the summit brand 3" ex kit on a e body ?
how well did it fit ?
how hard to install ?
where does it locate the mufflers ?
where does it exit ?
thank you !
Re: 3" exhaust e bodys ? [Re: calrobb2000] #1523097
10/25/13 03:56 AM
10/25/13 03:56 AM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
I bought one of the exhaust kits from Summit for my A-Body.. it was the 2.25" kit with Turbo mufflers... I had planned on doing it myself when I bought the kit but decided to just take it somewhere .. the exhaust shop that put it on said it was a Pain in the butt to put together, required a ton of cuts, and was not as easy as they advertised.
Re: 3" exhaust e bodys ? [Re: cal_gecko] #1523098
10/25/13 08:36 PM
10/25/13 08:36 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I put a 3" Summit system on my 69 Satellite... I love it. Just make sure you use the right style mufflers on it...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: 3" exhaust e bodys ? [Re: calrobb2000] #1523099
10/26/13 07:41 PM
10/26/13 07:41 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
I did not use anyone's manufactured 3" exhaust, because of the changes that were made to the rear end by the prior owner. However, I did buy/install TTI headers, and took the car to an exhaust shop to have a custom fabricated 3" exhaust made. I used Magnaflow mufflers, and 3" reproduction stainless exhaust tips. Of course, custom fabrication will typically cost more $$$ than a Summit (or other) system, but IMO it was worth it.
Re: 3" exhaust e bodys ? [Re: calrobb2000] #1523100
10/27/13 04:13 AM
10/27/13 04:13 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
It locates the mufflers on either side of the fuel tank. I used Super Comp headers and cut about 3" of pipe from one side and bolted it in. Not a great fit but OK for the $$$$. Exhaust is an odd location. Have not tried putting tips on it yet.
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523101
10/27/13 04:15 AM
10/27/13 04:15 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
It locates the mufflers on either side of the fuel tank. I used Super Comp headers and cut about 3" of pipe from one side and bolted it in. Not a great fit but OK for the $$$$. Have not tried putting tips on it yet. The kit comes with turn-downs at the end.
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523102
10/28/13 02:12 AM
10/28/13 02:12 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
The pipes tuck up OK under the body.
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523103
10/28/13 02:15 AM
10/28/13 02:15 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
The mufflers are on either side of the gas tank. The fit is tight! I actually rotated them slightly so they would fit so they are not entirely parallel with the ground. Ignore the turn downs I know it needs tips...
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523104
10/28/13 02:20 AM
10/28/13 02:20 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I don't know what brand of "turbo" mufflers Summit uses. Maybe there is a mark on the other side of the muffler but I didn't see anything tonight. I like the way they sound.
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523105
10/30/13 05:15 PM
10/30/13 05:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
From what little can be seen in the pics i suspect they are Flowtech Afterburner mufflers part#50330 and yes they usualy sound real nice
Re: 3" exhaust e bodys ? [Re: 1Fast340] #1523106
11/06/13 03:33 AM
11/06/13 03:33 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
The Summit mufflers are offset at the inlet.
Re: 3" exhaust e bodys ? [Re: Tom_440] #1523107
11/06/13 03:34 AM
11/06/13 03:34 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
And centered at the outlet.
