Tremec TKO 600? #1522860
10/24/13 07:01 PM
10/24/13 07:01 PM
Oppdal, Norway
trysilhemi Offline OP
Oppdal, Norway
I have a Brand new Tremec TKO 600 that's been upgraded with Carbonfiber blocker rings for better high RPM shift quality,this job got done by Keisler before I got the transmission. My problem is that it grinds when i shift from 3rd to 4th and downshifting from 5th to 4th Even in low RPM.
What can the problem be?
Please help.
Re: Tremec TKO 600? [Re: trysilhemi] #1522861
10/24/13 07:33 PM
10/24/13 07:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Please help.
Keisler is the problem, I would get on the horn with them and have them fix it.
Don't be the exception.
Re: Tremec TKO 600? [Re: trysilhemi] #1522862
10/24/13 07:58 PM
10/24/13 07:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What fluid are you running in it?....
Re: Tremec TKO 600? [Re: trysilhemi] #1522863
10/24/13 08:26 PM
10/24/13 08:26 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Just for background, was the upgrade a repair or is this the first time ever for the tranny in a car?
To THO users, does this tranny break in at all and improve with time?
Its in Norway? Ouch.
Re: Tremec TKO 600? [Re: jcc] #1522864
10/25/13 12:06 AM
10/25/13 12:06 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Mine was bone stock as Tremec built it and high rpm shift quality sucked. Period.
It never 'broke in' like promised.
Light throttle casual driving it shifted like butter, but when I got on it and the RPMs were up, it was like trying to shift without a clutch
The T56 I have now shifts great at any RPM
**Photobucket sucks**
Re: Tremec TKO 600? [Re: DAYCLONA] #1522865
10/27/13 06:21 AM
10/27/13 06:21 AM
Oppdal, Norway
Oppdal, Norway
Running GM synchromesh witch is recomended by Tremec
Re: Tremec TKO 600? [Re: jcc] #1522866
10/27/13 06:24 AM
10/27/13 06:24 AM
Oppdal, Norway
Oppdal, Norway
the transmission was band new and the upgrade was done before the first tme install.
Re: Tremec TKO 600? [Re: trysilhemi] #1522867
10/27/13 09:58 AM
10/27/13 09:58 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My bud has one of those behind a 528 roller hemi. He has broke it twice and done all the upgrades. It shifts like a Mack truck. I would not own one of those.
Re: Tremec TKO 600? [Re: trysilhemi] #1522868
10/27/13 01:40 PM
10/27/13 01:40 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Hi, Erik, sorry to hear about this. Did you buy it from Keisler direct, or through a Norwegian company? I know Anders Ringstad has imported some of these gearboxes, and maybe he can assist you in some way? I am currently putting a 5 speed Keisler behind a 440 for a client, and there have been some issues with lacking hardware and non fitting parts. Hope this gearbox works! What sort of car do you have?
Kind regards from Norway.
Re: Tremec TKO 600? [Re: Oyvind Mopar] #1522869
10/27/13 03:27 PM
10/27/13 03:27 PM
Oppdal, Norway
Oppdal, Norway
thanks a lot for the advice Øyvind, I know Aanders well ans that was sort of my back up plan. the tranny is sitting in my 1970 cuda.
Re: Tremec TKO 600? [Re: fastmark] #1522870
10/27/13 04:32 PM
10/27/13 04:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I have a 600 new still in the box, intended use was non competitive road race, likely never above 6K shifts, but a missed shift up or down on a road race car usually means the guard rails get real close and friendly. Everyone knows what they cost brand new, is it usable, or just suck it up and dump it and bypass all the aggravation?
Re: Tremec TKO 600? [Re: trysilhemi] #1522871
10/27/13 05:31 PM
10/27/13 05:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
GM Synchromesh is what's generally recommended in the TKO running bronze...not Carbon Fiber, I believe you've been misinformed by either Keisler or Tremec
When running the Carbon Fiber rings, Syncromesh is ONLY recommended for extremely hot climates, in cold climate use with Carbon Fiber rings, generally synthetics are to be avoided....either Amsoil ATF or Dextron III (Tremecs recommendation) is used, Redline D4ATF is a good all climate choice with Carbon Fiber rings (although Tremec won't endorse it, many TKO guys run it)....IMHO, and a decade+ of running/installing Keisler/TKO products, your fluid choice is the root cause of your problems, that's why I asked you initially what fluid your running
FYI...IIRC, Keisler still outsources the carbon fiber upgrade done to the TKO
Mike
Re: Tremec TKO 600? [Re: DAYCLONA] #1522872
10/27/13 08:01 PM
10/27/13 08:01 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I tried syncromesh and ATF. Neither one had any affect on poor shifting.
Re: Tremec TKO 600? [Re: 70Cuda383] #1522873
10/28/13 01:23 AM
10/28/13 01:23 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Up to this date. I've never seen a TKO600 shifted fast at high rpm.
If anyone ever has or seen it. Prove it here with an in car video. I hear the 500's are not much better.
Re: Tremec TKO 600? [Re: DAYCLONA] #1522874
10/28/13 06:41 PM
10/28/13 06:41 PM
Oppdal, Norway
Oppdal, Norway
Thanks for the info Mike! The thing is that the problem is There Even in low RPM shifts. I have also used dextron III but with the same poor result on olnly on up shift to 4th and from 5th to 4th.
What weight oil should i try?
What's the name of the company that do the blocker ring upgrades for Keisler?
Re: Tremec TKO 600? [Re: trysilhemi] #1522875
10/29/13 06:37 PM
10/29/13 06:37 PM
Norway
General 68 Offline
General 68  Offline
Norway
Hello
My TKO 600 also is hard to shift and a little slow but does not grind. I run carbon sync rings from Liberty. What I just found is that the clutch is not disengaging properly. I had the clutch pedal throw adjusted to one inch beyond the point where the rear wheels were not moving when on stands. I had to adjust in quite a bit more clutch throw to free the shifts. This made a huge difference in the way it shifts. This resulted in a pedal throw too long for my likings so I have to dig into a clutch/release issue here. Just wanted to share as this tells that some drag is taken up inside the trans and can mask a small lack of clutch release. I have only used syncromesh after upgrading to carbon rings. I tried both atf and syncromesh with the standard rings without any notisable difference. Good luck!
Re: Tremec TKO 600? [Re: trysilhemi] #1522876
10/31/13 10:40 PM
10/31/13 10:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Please help.
Did you dial in the bell housing?
