Noisy blower
#1522582
10/24/13 10:15 AM
10/24/13 10:15 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Is it the straight cut gear in the blower or the belt and pulley's that makes the nice sound? Thanks
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Noisy blower
[Re: DusterDave]
#1522586
10/24/13 01:28 PM
10/24/13 01:28 PM
Challenger 1
Cincinnati, Ohio
Belt and pulleys.
Kevin
From what I've read, the blower whine comes from the air getting compressed where the belt teeth engage the pulley teeth.
Could be, I don't know for sure. I have always been strapped in a dragster with zoomie pipes and I don't think you could hear the belt, but you sure hear the whine of the screw blower.
Re: Noisy blower
[Re: MrSixpack]
#1522587
10/24/13 02:04 PM
10/24/13 02:04 PM
Posts: 427 Sweden
Mopar Guy
Sweden
Hi Micke, The belt shore is noise so that should be what you like then Hope al is well /Pat down south
Re: Noisy blower
[Re: Cab_Burge]
#1522589
10/24/13 02:25 PM
10/24/13 02:25 PM
MrSixpack
Stockholm, Sweden
Its a 6/71 striped BDS blower for nostalgia racing. Thanks
1968 Mini Cooper
Re: Noisy blower
[Re: Cab_Burge]
#1522591
10/24/13 03:19 PM
10/24/13 03:19 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I think the front drive gears on the Roots blowers are what make the most noise, maybe not
I'm sure they contribute to "the sound" but my understanding is that as the belt cogs engage the pulley, they displace the air in the grooves at very high speed thus the "whistle".
Kevin
Re: Noisy blower
[Re: Challenger 1]
#1522592
10/24/13 04:26 PM
10/24/13 04:26 PM
Posts: 2,091 Delray beach, Florida
Performance Only
IMO, to hear the sweet sound, you must run a screw blower. It's not the belt, it's the rotors that you are hearing and a screw blower sounds so sweet.
I agree, nothing sounds as sweet as that. I just freshened a customers screw blown pro-mod with 11 MM pitch on the belt. There's a lot going on with the drive gears, the screw rotors and belt pitch. It's hard to tell where the sound actually comes from, but I think all three area's contribute.
machine shop owner and engine builder
Re: Noisy blower
[Re: DusterDave]
#1522593
11/02/13 05:01 AM
11/02/13 05:01 AM
Posts: 26 North Carolina
southernman
North Carolina
Duster Dave, you are absolutely correct; It is the sound of air being compressed between the belt and pulleys.
In an effort to reduce noise, some resort to drilling holes in bottom of the pulley grooves to reduce pressure, thereby reducing the noise, but it's a small reduction at best and not worth the time.
In fact, if you remove the belt and simply spin the blower, the snout has it's own oil reservoir, running with angle-cut gears in most cases, and they don't make much noise at all.
Again, its the belt and pulleys that make the noise, and what a sweet noise it is !
Southernman
Re: Noisy blower
[Re: southernman]
#1522594
11/02/13 07:59 AM
11/02/13 07:59 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Southernman
Winna-winna!! Chicken dinna!!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Noisy blower
[Re: DusterDave]
#1522595
11/02/13 12:37 PM
11/02/13 12:37 PM
Why then do some whine like a banshee and some run fairly quite? I could see 1/2" pitch being noisier due to more surface area compared to say 8mm. I have a Littlefield 14-71 with 8mm drive assembly for the Hemi and I don't like that really loud screeching whine I have heard on some cars so Dan I hope you read this LOL. There is a guy in town with a black 55 chevy with 600+ cubes running a roots blower and not much wine to it and sounds badass to the bone and man this 55 goes......
Re: Noisy blower
[Re: MrSixpack]
#1522598
11/02/13 09:18 PM
11/02/13 09:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Depending on the blower, there is some level of gear noise. Even the small blowers with serp belt setups have some whine. The "71" series blowers make some level of gear whine even in thier intended application(gear driven diesels). That beeing said, I've dealt with a few blower cars, all had 14mm belts. The noise the belt makes far exceedes the noise the gears make. I've also found(contradictory to what I thought) that the tighter you run the belt tension, the quieter the belt noise is. This may not be true with other belt styles, but it's been self proven to me on the two cars I've messed with.
