Re: 71 Dart SBP>BBP conversion (front) .. I forget!!!
[Re: cal_gecko]
#1522535
10/24/13 10:42 AM
10/24/13 10:42 AM
RapidRobert
You'd need the disc spindle of course & everything outward on it (rotor/horseshoe adapters/calipers/bearings/bolts). The LCA is the same & need the 73-76 UCA's or I believe someone sells a tapered spacer so you can reuse the early UCA since the disc spindle upper hole is larger (since the later ball joint dia/taper is larger) & needs a sleeve to take up that space. As Franken said use 76 A body calipers (2.75" bore) (remans are pretty reliable/cheap). The spindles are mirror images of each other & interchange from side to side & I'd mount em so the brake hard line/hose frame mounting tab is on the opposite side (front to rear) as the caliper unless sway bars make you mount em on the back side. In other words if the frame tab is rearward/behind the spindle then mount the calipers to the front side & vice versa & if you need a longer hose use one from a 78 volare & cut off HALF of the metal bracket clamped on the middle of the hose.
[Re: cal_gecko]
#1522537
10/24/13 12:00 PM
10/24/13 12:00 PM
RapidRobert
Highly likely that later UCA's were used instead of the earlier ones with the spacers so actually the only later (73 up) pieces (2) you need for the rebuild would be (73 up) upper ball joints, 1 on each side & (2) (73 up) disc lower ball joints.
[Re: RapidRobert]
#1522538
10/24/13 12:30 PM
10/24/13 12:30 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
And 73 up UCA bushings too, right?
[Re: cal_gecko]
#1522539
10/24/13 12:45 PM
10/24/13 12:45 PM
RapidRobert
I am almost positive that the 4 small UCA bushings (2 per side) are the same (early/late) since I think the Moog offset bushings for that are the same for early/later
[Re: RapidRobert]
#1522540
10/24/13 01:02 PM
10/24/13 01:02 PM
cal_gecko
Sacramento, CA
Thanks .. I'll check the part numbers.
[Re: RapidRobert]
#1522542
10/24/13 02:37 PM
10/24/13 02:37 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
disc and drum lower ball joints are the same 73-76.
