340 exhaust manifold pictres needed - correct overspray
#1522405
10/23/13 10:13 PM
10/23/13 10:13 PM
Posts: 11,840 Florida
mopar346
Let me tell ya about fat chicks!
I need some good pictures to show my powder coater the basic engine paint overspray pattern.
Careful, your character's showing!
Re: 340 exhaust manifold pictres needed - correct overspray
[Re: kentj340]
#1522409
10/24/13 07:22 AM
10/24/13 07:22 AM
mopar346
Thanks guys, I am familiar with most everything you discribe and have described it to him. I just wante pictures to give him a visual and yes it would be tough for him to get the burned off effect, but the best chance he has is to have pictures.
[Re: 472 R/T SE]
#1522411
10/24/13 09:56 AM
10/24/13 09:56 AM
mopar346
Well, I have seen hi-tem powder coating retain the look, I just don't have any pictures. Surely someone on Moparts has done it and/or has some pictures.
[Re: ScottSmith_Harms]
#1522413
10/24/13 12:55 PM
10/24/13 12:55 PM
mopar346
No not as an assemble, I hae seen what I a talking about at shows plenty of times I just cant find a good picture. It is completely cast color and then appears oversprayed at the top, heavy in the beginning and fading out as it gets further away from the flange. Here is one of the only pictures I can find.
[Re: mopar346]
#1522415
10/24/13 01:30 PM
10/24/13 01:30 PM
Posts: 2,647 Nashville, TN
MOPARMIKE69
Nashville, TN
Pictures are not showing up. If you want to make it really factory you have to paint the engine and manifolds etc together. Also no paint on the manifolds before painting the orange. That cannot be done with the powdercoating process. You can "simulate" the factory process by painting or ceramic coating the manifolds off the car, and hitting them with paint around the edge, but it will only simulate the look. My  says you have to commit. Either have the manifolds look nice and not paint them with engine paint, or do it like the factory and have them burn off and rust. Or never start the car?
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
#1522417
10/24/13 02:28 PM
10/24/13 02:28 PM
Posts: 6,249 JERSEY
RJS
JERSEY
I usually have them ceramic coated and then bolt on and shoot the engine. This last set were powder coated silver/gray bolted on and shot. Like Scott said whatever burns off burns off, why over complicate the process? Ron
[Re: RJS]
#1522418
10/24/13 02:41 PM
10/24/13 02:41 PM
Posts: 3,132 across the river from Portland...
472 R/T SE
For some people, it's part of the fun.
[Re: RJS]
#1522419
10/24/13 02:44 PM
10/24/13 02:44 PM
mopar346
That is the problem with my AAR, I get too caught up in aking it right or what is currently perceived to be right. It would be so much more fun to build it just to look good and be enjoyable.
Thanks for the input, on to another subject.
#1522422
10/24/13 07:37 PM
10/24/13 07:37 PM
mopar346
YOU asked for "correct" and you got some good/accurate replies. There's no grey area ("currently perceived") about it. The way the facyory did it is well known and documented, doing it any other way is simply NOT correct.
I undestand, agree, respect and appreciate all the information supplied. I realize most everything known is pretty solid at this point but new information surfaces still today. The orange small block cut off for instance. At one time it was thought that the fender black out was done with a cardboard template covering the engine compartment and sprayed afer the body was pnted, it is now understood that the black was sprayed first. Cars restored to what was thought to be crrect 15-20 years ago are now moched for being incorrect, but that was info available at that time. Not arguing any points above, just tryng to be as correct appearing and durable all at the same time. I am very analytical many times to a fault, but that is something I have to come to grips with.
[Re: mopar346]
#1522423
10/24/13 08:22 PM
10/24/13 08:22 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh make no mistake, I agree completely on the subject of details that we either have wrong, will be discovered later, or possibly never be discovered due to the passage of time and loss of untouched original reference examples or factory supportive documentation. However, when it comes to the paint coverage on 340 exhaust manifolds that you specifically asked about, you can bank on the current knowledge being accurate, that's an easy one! Respect back at you!
As far as the 71 340 engine color cutoff date, so far all we have to go by are surviving examples, I have yet to see a factory document which details the changeover date, hopefully someday it will surface, but I sort of doubt it ever will. Concerning my post on the subject elsewhere, that was my attempt to share/add to a rather recent discovery, but that discovery didn't really change the (yet unknown exact cutoff date) but rather tossed in a "Never say never" example of a car that received an orange engine way past the blue/orange changeover date simply due to an earlier built engine being installed LONG after it was intended due to some problem with the engine or inventory.
#1522424
10/24/13 09:28 PM
10/24/13 09:28 PM
mopar346
I agree the exhaust manifolds are known issues at this point. I have seen what I am talking about and it looks good in my opinion but yes only correct looking until they were cranked and run.
Above I think it was mentions to spray engine paint over the powder/ceramic coating and let it naturally burn off. Has anyone done that and does it leave a stain on the coating were the paint was?
