Can I hone my own cylinders ? #1522126
10/23/13 03:08 PM
10/23/13 03:08 PM
Penna
70satelliteguy Offline OP
Penna
Putting my race motor back together(440 block) and will be replacing the rings. Can I hone my own cylinders to ensure that My rings seat or will the machine shop do a much better job?
Where can I get a good ball hone to do the job?
Thanks MIke
Re: Can I hone my own cylinders ? [Re: 70satelliteguy] #1522127
10/23/13 03:14 PM
10/23/13 03:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes you can, Goodson is the place to go for engine building tools. So much to learn by reading there catalog. Good luck.
Re: Can I hone my own cylinders ? [Re: 70satelliteguy] #1522128
10/23/13 03:16 PM
10/23/13 03:16 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Can I hone my own cylinders ? [Re: 70satelliteguy] #1522129
10/23/13 03:21 PM
10/23/13 03:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thanks MIke
a ball hone is nothing more than a glaze breaker and a hone will help ring seal by giving the proper cross hatch and surface finish, I personally wouldn't ball hone but I am sure someone is going to me for saying that, and another is going to say "that's all I ever do", personal preference I suppose.
Re: Can I hone my own cylinders ? [Re: 70satelliteguy] #1522130
10/23/13 03:30 PM
10/23/13 03:30 PM
Delray beach, Florida
P
Performance Only Offline
P
Sure you can. Of course that doesn't mean you'll get the result you're looking for. a lot depends on the current condition of the cylinders (taper, wear, straightness top to bottom etc.) and your experience level to get a decent cross hatch finish that's suitable for the rings you're going to use.
Yes, a machinist will do a better job.
machine shop owner and engine builder
Re: Can I hone my own cylinders ? [Re: Performance Only] #1522131
10/23/13 04:00 PM
10/23/13 04:00 PM
Cincinnati, Ohio
Cincinnati, Ohio
I invested in this years ago to be able to do sleeves in the block at the race track.
Ball hone won't straighten or improve the roundness.
To use this hone you need:
a bore gauge. a badass drill, gloves, big arms, strong back and lot's of honing oil.
I setup a gravity feed for my honing oil, I have used mostly AW 32 10 weight hydraulic oil and it don't get reused, goes on the ground on trays.
I have also used Goodson oil and did not see any difference.
I have done pretty many street engines now with it also, does a good job for me and keeps me out of those terrible machine shops.
Years ago I agreed to buy a CK-10 from a used machine dealer here in town. I gave him a small down payment and then waited like over a year for him to get it out of some shop to sell to me.
Before that could happen I bought my first BAE blown hemi which cost 3X as much as the hone was going to cost. So I never bought the hone because I was too busy and tapped out racing.
So I settled for this hand held hone which works for me.
I'm sure a real shop hone operated by one those evil machinist would be better, but I'm too cheap with my time to wait on a machine shop, I like control.
I realize a ball hone would be good to use after a real hone although I never have.
Re: Can I hone my own cylinders ? [Re: Challenger 1] #1522132
10/23/13 04:52 PM
10/23/13 04:52 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Just called a local shop to have mine just honed as it's fresh but was sitting for 10+ years & has some marks from where the pistons sat in the bores. Anyways, they only wanted $80 to hone it. A good hone will cost more than that I'm sure. Oh & they said it would only be a week or so because it's a simple job.
Re: Can I hone my own cylinders ? [Re: Performance Only] #1522133
10/23/13 05:19 PM
10/23/13 05:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That all depends on the machinist doing the job , remember that 383 I sent to you ???
Re: Can I hone my own cylinders ? [Re: JohnRR] #1522134
10/23/13 05:34 PM
10/23/13 05:34 PM
Cincinnati, Ohio
Cincinnati, Ohio
You made me feel bad a while back because I don't have a torque plate.
Still don't but would not mind one.
Re: Can I hone my own cylinders ? [Re: Performance Only] #1522135
10/23/13 05:55 PM
10/23/13 05:55 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Can you ? Should you? not likely........ Get it honed with a rigid hone and torque plates.........BTW I'm a licensed machinist with a rigid hone........ I get mine done on a machine.........
Now that you have a good hone job......... you can buy a decent ring package and make more power with less wear and tear on your engine.
Re: Can I hone my own cylinders ? [Re: Challenger 1] #1522136
10/23/13 06:28 PM
10/23/13 06:28 PM
P
P
Those AN style hones are great tools in the right, experienced hands. In the hands of a novice they'll totally screw up a cylinder in a hurry. And yes, get ready for a workout if you ever go that route.
Re: Can I hone my own cylinders ? [Re: JohnRR] #1522137
10/23/13 06:31 PM
10/23/13 06:31 PM
P
P
John, that 383 was one of the worst hone jobs I've ever seen. If I recall there was more than a few thousandth's of taper and out of round in that one. That was a tricky one to bring back to straight, round bores without going to the next full oversize.
Re: Can I hone my own cylinders ? [Re: Challenger 1] #1522138
10/24/13 01:53 PM
10/24/13 01:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have 2 ... one for small bore BB and one for 4.500 bore ...
Re: Can I hone my own cylinders ? [Re: Performance Only] #1522139
10/25/13 08:10 AM
10/25/13 08:10 AM
408Dust Offline
408Dust  Offline
How would we ever do this with out inside secrets from the Performance only shop.
Re: Can I hone my own cylinders ? [Re: 408Dust] #1522140
10/25/13 12:49 PM
10/25/13 12:49 PM
organ
maximum entropy Offline
organ
i ball hone mine all the time, BUT, i also have a bore gauge, torque plate (for measuring), and i know my cylinders are round and true. if they aren't, off to the machine shop she goes!
Re: Can I hone my own cylinders ? [Re: maximum entropy] #1522141
10/25/13 03:42 PM
10/25/13 03:42 PM
sweden
sshemi Offline
sshemi  Offline
sweden
If the hone is fresch i would just try to clean it with whatever and if it doesnt work i would do a ball hone.
If you know the job is good.
