Wheel Studs #1522115
10/23/13 02:48 PM
10/23/13 02:48 PM
London, England
JFChallenger440 Offline OP
London, England
Does anyone have a code or link to what wheel studs I need for the front of my 68 Charger ? I have disc brakes on the front and a spacer so I need them to be about 1/2 inch longer that the standard rear studs, reason for the spacer is the wheels I want to buy have a 3.75" backspace so I think they will hit the calipers without the spacer, thanks
Re: Wheel Studs [Re: JFChallenger440] #1522116
10/23/13 09:04 PM
10/23/13 09:04 PM
You might mock em up & see if the wheels clear the caliper as is. Here's a BTT for ya
Re: Wheel Studs [Re: RapidRobert] #1522117
10/23/13 09:43 PM
10/23/13 09:43 PM
IN
ahy Offline
ahy  Offline
IN
I have used the 3" MP studs sold by Mancini with good results. Their sales information identifies which studs go with which model/brake application. I have put both front and rear on without issue ('70E).
Re: Wheel Studs [Re: JFChallenger440] #1522118
10/24/13 03:10 AM
10/24/13 03:10 AM
I would NOT use wheel spacers on the front
Re: Wheel Studs [Re: Cab_Burge] #1522119
10/24/13 07:53 AM
10/24/13 07:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
nothing to worry about with spacers on the front. I know MANY Dakota owners (myself included) who used 5/8" slip on spacers on the front when they ran stock wheels with viper brake calipers.
not a single one had a failure and they are anything but show queens.
a quality spacer and quality wheel studs, once all put together and lug nuts torqued down, is no different than a single wheel with a thicker mounting pad to space it out.
now...I would not use a cast spacer ever. be sure to use quality CNC billet aluminum.
**Photobucket sucks**
Re: Wheel Studs [Re: 70Cuda383] #1522120
10/24/13 07:56 AM
10/24/13 07:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
billet CNC Aluminum, hub and wheel centric. about $150 a pair.
