Dodge Dart GT door hinges #1522068
10/23/13 02:23 PM
10/23/13 02:23 PM
N. Chesterfield Va
68dartgtman Offline OP
N. Chesterfield Va
Is it hard to replace door hinge pins & bushings or should I just replace the hinges?
Re: Dodge Dart GT door hinges [Re: 68dartgtman] #1522069
10/23/13 05:11 PM
10/23/13 05:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We do the pins and bushings all the time. The hardest part is getting everything lined up IE: doors, windows etc. I have found it's a good idea to take a picture of the hinge before disassembly to prevent mixing things up. Film is really cheap these days LOL
Re: Dodge Dart GT door hinges [Re: TJP] #1522070
10/24/13 04:54 AM
10/24/13 04:54 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Rebuilt hinges should work like new. The upper hinges came from the factory with bushings that can be replaced, and the lowers did not come with bushings. The best way to redo the lowers is to install an oversize pin, not drill for a bushing. For a kit to do this, see:
http://www.restorick.com/proddetail.asp?prod=DrHingeRebuildKit
To dis-assemble/assemble, take more photos than you think you need as mentioned. You can easily remove the S spring by clamping it in a vise as shown, then apply torque to the top of it with a Crescent wrench, and let the hinge slide down.
Re: Dodge Dart GT door hinges [Re: TJP] #1522071
10/24/13 11:43 AM
10/24/13 11:43 AM
N. Chesterfield Va
N. Chesterfield Va
Thank you very much !
Re: Dodge Dart GT door hinges [Re: kentj340] #1522072
10/24/13 11:49 AM
10/24/13 11:49 AM
N. Chesterfield Va
N. Chesterfield Va
Hey, Thank you very much !!!
Re: Dodge Dart GT door hinges [Re: 68dartgtman] #1522073
10/24/13 12:36 PM
10/24/13 12:36 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If you don't want to build them yourself you could buy from Bob Kropp. He builds an improved version with stainless steel pins that are greasable. Check out the website www.superbirdbob.com
I have bought his parts, he is a friend and one of the good guys.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
